Baja Designs
Gold Sponsor
- First Name
- Baja Designs
- Joined
- Apr 29, 2019
- Threads
- 34
- Messages
- 151
- Reaction score
- 164
- Location
- San Marcos, California
- Vehicle(s)
- 2018 Silverado H.D.
- Thread starter
- #1
Reflex Light Actuator: Complete Light Control at Your Fingertips
Introducing the Reflex Light Actuator (Patent Pending) – the first fully compatible actuator system designed exclusively for the Baja Designs light lineup. Born from racing in Baja, the Reflex brings professional race-level engineering to a consumer-ready solution. Engineered exclusively for our lights, the Reflex delivers instant, on-the-fly control of light pitch angle. This is the first fully integrated actuator system designed exclusively for the entire Baja Designs light lineup. It’s race-level technology, engineered into a bolt-on solution that anyone can install and use.
Born in Baja
In desert racing, race trucks run 125-gallon fuel cells that burn off hundreds of pounds of fuel over 1,000 miles, progressively lightening the rear end and changing the vehicle’s pitch. Combined with constantly shifting terrain – climbs, straights, blind crests – drivers need instant beam angle adjustment. Fixed angles don’t work. Stopping isn’t an option. Race teams solved this with actuators, but these required custom fabrication and were not cheap – they were out of reach for everyone else. So we thought, why not make a consumer-level light actuator that bolts directly to a Baja Designs light? And that is exactly what we did. Best of all, the Reflex Actuator is compatible with the LP Series, XL Series, S8, and OnX6+ light bars.
Why Add Light Actuators to Your Setup?
1. Gain Control over your Lights – Instead of settling for a fixed light angle, actuators let you adapt instantly—aim high for open terrain or lower the beam for fog, dust, and close-range obstacles.
2. Improve Light Efficiency – Proper beam placement reduces glare, prevents wasted output, and ensures maximum penetration where you need it most.
3. Increase Versatility – From rock crawling to high-speed desert driving, actuators make your lighting system perform better in every scenario.
Aim Your Lights Exactly Where You Need It
The Reflex gives you complete control without leaving the driver’s seat. Previously, achieving this meant either stopping to manually adjust your lights or investing in custom actuator setups that required fabrication work. Neither option was practical for most drivers. Climbing a steep hill? Adjust your beam upward. Descending or running high-speed sections? Bring it down. Towing a loaded trailer that’s squatting your rear suspension? Adjust your light instantly. Aim your light exactly where you need it. We engineered the Reflex to eliminate that barrier entirely.
Purpose-Built Integration
What makes the Reflex different is that it’s designed exclusively for Baja Designs lights. The result is a true bolt-on installation using included custom hardware. No fabrication required. No modification of existing brackets. The system mounts directly to your Baja Designs light brackets and integrates seamlessly with the harness available.
Features
- Instant pitch angle adjustment up to 20 degrees
- True bolt-on installation – mounts directly to Baja Designs light brackets
- Custom hardware included
- Universal compatibility – works with most vehicle specific kits
- Connect multiple actuators to vehicle-specific together using our actuator harnesses
- Reliability backed by Baja Designs Limited Lifetime Warranty
Empty heading
Light Compatibility
Light Compatibility
- LP4/LP6/LP9
- XL-M Shallow Housing
- XL Standard Housing
- OnX6 Light Bars (all lengths)
- S8 Light Bars (all lengths)
Specific Wiring Harnesses for Control
You choose how you want to control the Reflex Light Actuator. Harnesses are sold separately to provide flexibility for customers’ existing lighting setups. With two styles of wiring harnesses to select from provides flexibility to control your lights how you want. Wiring harnesses for control via momentary switch or power control modules (sPOD, SwitchPros, and others), take control of your lights at the push of a button.
Control Multiple Actuators at Once
Need the ability to control multiple actuators at once on your lighting setup? The Reflex Actuator linking harness can be used to power multiple actuators using one switch. For example, to actuate a 4-light LP9 bumper setup with a momentary switch and one actuator per light: (1x) Momentary or rocker single lead actuator harness and (1x) 4XL Linkable Harness. *Note: Actuators are not compatible with XL Linkable light bars. XL Linkable Harnesses are power-only between individual light actuators.
Built for Real-World Application
The Reflex Light Actuator is designed for any off-road platform. Whether you’re building a dedicated prerunner, weekend trail rig, outfitting a daily driver, or overland rig, the Reflex delivers the same level of performance and reliability.
Light actuators were previously reserved for professional racing applications and custom builds. We’ve engineered it into a consumer-ready solution that any driver can install and benefit from immediately. This is only adding to our goal to make lights that not only give you a competitive edge in racing but can be reliable enough to get you home safely.
Race-Proven Engineering
Every Baja Designs product carries our commitment to performance, innovation, and reliability. The Reflex Light Actuator embodies our “Scientists of Lighting” approach – rigorous engineering, extensive testing, and real-world validation before launch.
The Reflex Light Actuator introduces a new segment in performance lighting: accessible, integrated actuator control. We’re creating a purpose-built system that makes advanced light control available to anyone who wants it.
BUY NOW !!!!!
Best,You choose how you want to control the Reflex Light Actuator. Harnesses are sold separately to provide flexibility for customers’ existing lighting setups. With two styles of wiring harnesses to select from provides flexibility to control your lights how you want. Wiring harnesses for control via momentary switch or power control modules (sPOD, SwitchPros, and others), take control of your lights at the push of a button.
BUY NOW !!!!!
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
