HeavyDuty
- First Name
- Kevin
- Joined
- Mar 28, 2021
- Threads
- 55
- Messages
- 312
- Reaction score
- 1,044
- Location
- East of Nashville
- Vehicle(s)
- 2021 Lariat, FOX 2.0 (set at 2"), 275 65 R18
- Occupation
- Builder, Restorer
- Thread starter
- #1
They say that they are respective of maitaining geometry with their spacer lift.
https://bds-suspension.com/products/2-5-inch-lift-kit-ford-ranger-19-23-4wd
"Properly level the front of your 2019-2023 Ford Ranger truck by installing this 2.5-inch leveling kit from BDS. Specially designed for the new Ranger, this 2.5" leveling kit is engineered for additional tire clearance and improved performance without overextending the suspension or driveline angles at full suspension droop.
To prevent maxing out ball joints or CV damage, BDS gets around this issue by using a 2-piece design with a smaller top mounted steel strut spacer in combination with a preload spacer. To further ensure proper drivetrain geometry the front differential is repositioned using relocation brackets. These brackets correct CV axle angle while allowing the use of the factory front skid plates."
Sure sounds good to me if it is worth the extra bucks compared to the cheaper alternative.
Any thoughts or experience with this kit?
