3rd Brake Light replacement.
Keppie
Don
Indiana
2022 ranger Tremor
Retired Firefighter
3rd Brake Light replacement, can I just drop rear portion of headliner to access electrical connection? Also are clips on headliner same as used on dash- fuse access?
dozxab
Prescott AZ
I used a plastic trim tool to pull headliner down past the lip a little and carefully worked it down to give me the room I needed. At some point, I heard a plastic push pin pop out of its hole. When going back together, I just pushed up on the spot it was located and it popped back in.
dozxab
Prescott AZ
06Warrior
SW Florida
2020 Ford Ranger XLT
Staying busy
Yes you can pull the rear portion of the headliner down to access the electrical connectors.
Unfortunately I can’t remember if the headliner clips are the same as the dash clips.
