2017 Ford Ranger Wildtrak XLS Thailand RHD electrical question
MartyL16
Marty
Chiang Mai Thailand
2017 RHD FORD RANGER WILDTRACK 2.2 XLS
Retired military
I cannot find any wiring diagrams for this truck. Maybe someone can tell me where to find a ‘true negative ground’ point or wire near the tail lights. Trying to add some nice LED REAR LIGHTS but they only have ONE GROUND - neg wire for BRAKE and TURN SIGNAL. I have tried using the ‘ground/negative wire on the BRAKE LIGHT but it won’t let me use the TURN SIGNAL FUNCTION of this new light bar. Just for ‘fun’ I ran a piece of wire to the BATTERY NEG TERMINAL and BOTH BRAKE and TURN LED LIGHTS worked.
I do not want to put a ‘dedicated NEG WIRE’ from the battery to the back of the truck to permanently solve this problem. So now that I know what will solve the problem I am hoping some of you could help me find an ‘existing ground wire’.
I did try to just attach a wire to an existing screw underneath but that did not work.
That could have been the wrong screw as it was to the truck-bed, not the truck-frame.
Thank you
Hi Marty,
Do you have a trailer tow harness? If so, you have a good ground there. Any part of the frame is a good ground as well and a small hole drilled into the frame with a self tapping screw would likely work...
Good Luck,
MartyL16
Marty
Chiang Mai Thailand
Retired military
Hi Marty,
Good Luck,
No towing harness as that would make it too easy. Ha ha
I will try to do as you suggested.
thank you for your help.
