Front licence plate metal bracket
R_Willis
Ohio, USA
2014 Jeep Cherokee
Does the factory OEM bracket mount by them drilling holes thru your bumper?
Ohio no longer requires front plates and I do not want dealer drilling holes.
Thanks.
Here
XLT
Thanks.
Don’t worry Rob, there are threaded holes on the underside of the top portion of the bumper that the factory bracket bolts up into.
OrangeStreak
New Mexico
I put a bend in my plate and screwed up into the bumper. Had to ventilate it a bit for airflow.....
Did you take this plate to the shooting range? :LOL:
lukdeg
Luc
Edmundston
Ford Ranger lariat 2023 Cactus grey
paramedic
Not fancy, but I have the euro license plate frame on the front of my truck attached with heavy duty zip ties. They're secure, you can't see them and if they did break, they're super easy to replace.
can you snap a picture of your plate setup? I have an Eurpean plate that I want to fit up front, thanks1
lukdeg
Luc
Edmundston
paramedic
@lukdeg The zip ties are run through the slots in the plate frame (link to the one I have) and wrapped around the bumper. Unless you are looking they are invisible.
that bracket is the same as the one that came with my custom plate, Ill see on amazon if I can find something to use the existent hile under the bumper.
thanks!
