Sold: Georgia BuiltRight Industries Bedside Rack System
puda
Peter
GA
2024 Wrangler
Industrial Automation
I am selling the full molle panels for both sides of the 5' bed. I am including:
- Bedside rack system, drivers front side panel
- Bedside rack system, drivers rear side panel
- Bedside rack system, passenger front side panel
- Bedside rack system, passenger rear side panel
- Ford bedside tie-down hook kit
This sells for $705, I am asking $300. I will include the installed rotopax deluxe mount for another $50 and the installed air compressor and power distribution for another $250 (pictured).
EDIT: This also comes with the tie-down kit from Ford so you get the extra tie-down in the middle of the bed with the hardware for mounting.
1slow_ranger
Adrian
Commercial driver
Interested in the air compressor if you will sell separately.
puda
puda
Peter
GA
2024 Wrangler
Do you just want the compressor? I shortened a good bit of the harness since it's all right in one spot and removed the air locker stuff. I can include the air locker wiring harness. I just want to make sure you know that it's not the same as the harness it comes with.
1slow_ranger
Adrian
Commercial driver
Ill pass on the compressor i dont want to end up needing another harness thanks anyways
puda
puda
Peter
GA
2024 Wrangler
No worries. I'm an electrical guy so I'm pretty confident in this arena. If you don't need lockers the connections and wiring are greatly simplified, even more if you have the aux switches. I'm not trying to sell you, just posting the info for anyone else who may be curious as to what I modified. The way this is wired is the positive and negative from the battery get landed on the positive and negative bus bars (under the plastic cover) and the power from the on/off switch gets connected to the small loose red wire towards the bottom of the picture.
tjg0720
Travis
2022 Ranger FX4 SCrew
USMC
If you are willing to separate the passenger side with the rotopax mount I will take it!
puda
puda
Peter
GA
2024 Wrangler
Yes, I am willing to split it up. $200 for the passenger side with the Rotopax deluxe mount.
Russd
jeff
Arizona
Vw bus 4runner
Drivers side $?
puda
puda
Peter
GA
2024 Wrangler
$150 for the panels, another $250 if you want the compressor.
