Baja Designs New S1
Status
Not open for further replies.
OffroadAlliance
Brockton, MA & Houston, TX
www.offroadalliance.com
2019 Ranger, 2021 Raptor, 2022 F250, 2023 Bronco
The mad scientists over at Baja Designs just unveiled the latest creation, the Baja Designs S1. This small but mighty light packs a serious punch in a very compact housing.
At 2.1" x 2.1" x 2.1", it's a small footprint with an huge output of 2,375 lumens! Retail, $208.95/pair and $109.95/single. We have secured the entire first production run quantity of these so if you want a set, we've got them!
We've already got these up on the website! Forum member discounts of course so contact us today.
Website for Pair ---->>>> OFFROADLLIANCE.COM
Website for Single ---->>>> OFFROADALLIANCE.COM
Specifications:
Lumens: 2,375 Utilizing 1 LED
Wattage/Amps: 20W / 1.45A
Dimensions: 2.1" x 2.1" x 2.1"
Weight: 0.4 lbs
LED Life Expectancy: 49,930 Hours
Front Lens: Hard Coated Polycarbonate
Housing: Hard Anodized & Powder Coated Cast Aluminum
Bezel: Billet Machined Aluminum
Hardware & Bracket Material: Stainless Steel
Exceeds MIL-STD810G (Mil-Spec Testing)
Built-In Overvoltage Protection
IP69K (Waterproof up to 9ft & Pressure Washable)
IK10 Compliant (Mechanical Impact Testing)
Fjsteven
Steven
Gilbert, Arizona
2019 Ranger Lariat 4x4 Sport
Ok. Help me out here.
They have spot, work, and wide cornering. I would like to light up the area in fro t of the truck to see as much as possible at night in the woods. Probably not spot in that case. But which of the other 2 would be best?
Thanks!
Baja Designs
Gold Sponsor
Baja Designs
San Marcos, California
2018 Silverado H.D.
Thanks!
If you want maximum coverage, you can always run 1-Spot and 1- Wide Cornering. This will give you nice distance coverage as well as a wide beam of light for nearfield areas.
OffroadAlliance
OffroadAlliance
Thanks!
The wide cornering have descent distance, but great width or flood lighting. Those would really help illuminate the area right in front of the truck but also a lot of light off to the sides.
Baja Designs
Gold Sponsor
Baja Designs
2018 Silverado H.D.
Will you make lazer S1?
It's not currently planned although that could change down the road
We are always looking for ways to improve our products or change things up!
Status
