Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
I know this has been posted before, but figured I would bring it to the proper area. In stock and ready to ship, if anyone is in the market, shoot me a message for forum pricing.
Frank
2019-2021 Ford Ranger ARB UVP Complete Steel Skit Plate Kit 5440230
Highlights:
Off-road ready Rangers that are going to see tough trails are going to need all the protection they can get to make it back in one piece, but there's not much from the factory to keep your critical driveline components safe from harm. That's where ARB's Under Vehicle Protection (UVP) Skid Plate Kit for 2019-2021 Ford Ranger come in. ARB's UVP Skid Plates are made out of durable steel and give better protection to your Ranger's front end than the stock skid plate while also adding protection to your engine oil pan, steering rack, front differential, transmission and transfer case so that you don't break anything that will leave you stranded while you handle tough trails and overland adventures. The skid plates are each made out of durable, pressed and folded steel with a corrosion-resistant coating that helps keep your truck protected in nearly any application or climate. The ARB Ranger UVP Skid Plate Package bolt directly onto your truck with ARB's included hardware, making it easy to get the kit up and running on your tough Ranger build. 3mm Thick, Laser-Cut Steel Plates with Zinc Plated and Silver Powder Coated Finish
The ARB UVP Skid Plate Kit for the Ford Rangers is built extremely tough so that they take the hits that would usually leave your Ranger broken and stranded. Each skid plate included in this kit is made out of 3mm thick steel with folded return edges to help improve strength and durability. The skid plates are each laser-cut and expertly welded to give your Ranger a perfect fit. After construction, the skid plates are zinc-plated and powder-coated in a textured silver powder coat finish that gives them an eye-catching look and resistance to corrosion in almost any climate or application. The skid plates feature recessed mounting bolt provisions that keep the fasteners from getting sheared off during aggressive off-roading. The ARB UVP Skid Plates come with all their necessary installation hardware and instructions.
Fitment: 2019-2021 Ford Ranger.
Access panels not included: the skid plates do not come with access panels for oil and fluid changes. The skid plates will need to be removed for basic maintenance procedures.
Will not fit crossmember lifts or certain front bumpers: these skid plates will not fit Rangers equipped with crossmember lift kits or front bumpers that come with integrated front skid plates.
Frank
Highlights:
- Adds additional underside protection to your Ranger
- Includes three steel skid plates and hardware
- Protects engine, front differential, transmission, and transfer case
- 3mm, laser-cut steel with zinc plated and powder coat finish
- Straightforward, bolt-on installation
- Comes with hardware and instructions
