2019-2021 Ford Ranger 2.3L EcoBoost Mishimoto Cold Air Intake Kit w/ Oiled Filter MMAI-RGR-19
Status
Not open for further replies.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
IN stock and shipping.
Message me for forum pricing
Frank
Highlights:
  • Improves air flow over stock
  • Has oiled filter
  • Less restrictive than factory system
  • Adds a better sound & durability
  • Uses better components than stock
  • Features bolt-on installation
Improves Airflow & Sound without Hassles
The factory intake system of your 2019-2021 Ford Ranger can provide you clean, nice air. However, it doesn't always hold up the best after time and time again of braving harsh elements. The 2019-2021 Ford Ranger EcoBoost's air system can be revolutionized with Mishimoto's Cold Air Intake Kit. This product breathes much easier than its stock counterpart. The new intake kit improves airflow by 49% over stock, adds a new sound, and helps your system last longer. Safer air and fuel ratios are achieved without the assistance of custom tuning. A new, high-quality sound also helps you stand out in the crowd. More versatility is added due to its compatibility with larger, aftermarket intercooler pipes if you choose to install one. The intake additionally comes with a high-flow, high-capacity oiled filter. Includes Excellent Design
When examining the stock intake of the Ranger, Mishimoto discovered that the stock air duct was detrimental to air flow as a restriction point. The 2.3L EcoBoost Cold Air Intake Kit was carefully designed and engineered by Mishimoto to deliver excellent fitment and flow to your truck. The restrictive air duct was redesigned in Mishimoto's intake and placed instead in the rotational-molded air box. The inlet cross-section uses 40% more area, removes two bends in the air path, and shortened the path by 50% for better air flow. The stock intake hose also is replaced with a rotational-molded tube for more flow volume. The stock air box lid additionally has been replaced with a silicone grommet to connect the intake tube and air filter to the air box. This allows for more flexibility and engine movement. The kit is topped off with instructions and all the hardware necessary for installation. No cutting or modifications are required. Uses the Best Components
Mishimoto's intake system uses an XLPE, Cross-Linked Polyethylene plastic in its rotational-molded airbox and intake tube. THE XLPE material is not only stronger, but resists heat and UV rays. The kit's flexible grommet features injection-molded silicone to hold up against high heat levels in your engine bay. Silicone and a layer of MVMQ lining in the intake tube coupler helps fuel and oil resistance. Because of Mishimoto's specific material selections, this intake kit can withstand the rigors of frequent, intense drives.
Fitment: 2019-2021 Ford Ranger 2.3L EcoBoost
50-State Legal: this intake is 50-state street legal and is CARB approved under EO# D-418-38.
RedR@nger
Todd
Seattle, WA
2020 Ranger XLT FX4
Construction Safety
Frank
Highlights:
  • Has oiled filter
Frank
Highlights:
  • Has oiled filter
I was planning on ordering this next week, is it that much better than the Rousch?, Besides the fact that the Rousch is 4-6 weeks out on back order?
Stage3Motorsports
Stage3Motorsports
Joel
Phoenix Arizona
Sales Specialist
In this particulare case I think they are both going to be very similar in performance and function. My advice would be to get whichever one you either like the looks/price/availability of better.
Frank
Status
