Wiring into cab...
Glocker
Boca Raton
Where are you guys going through the firewall to get wiring into the cab for your front mounted lights? I poked around yesterday and saw only one option and it'd require buggering up a rubber boot around a harness going into the cab.
Bart
Bart
Buckeye AZ
2019 Ranger XLT supercrew fx4
Software engineer
passenger footwell, theres a few grommets at about glovebox height
gbritt89
Garret
Fort Worth Texas
2019 Ford Ranger STX
@Glocker I havent wired a light bar yet but ran a 12 gauge wire through the boot where the main bundle of wires comes through the firewall on the drivers side without issue while doing my trailer brake setup.
Seemed tight but stayed clear of the bundle of wires a good bit and poked through with a scratch awl. I then fished the wire from engine bay to cab by using a metal coat hanger poked through the opening at the cab side and mating it to the wire I fed through using electrical tape to overlap about a 2 inch section strong enough to help it guide through the puncture I had made with the awl.
