Good luck with that.We will be doing our formal Forum Intro/background later this week but make sure to check out The SVC Offroad Leveling collars.
https://www.svcoffroad.com/product-page/2019-ford-ranger-leveling-collar
I do believe the chief difference is one-half inch as you stated, reaching out to this company revealed that I should opt for the 3" lift kit instead of the 2 1/2" , since towing anything with the 2020 SuperCab with the FX2 option I have on order will never occur. It appears that the added tongue weight of whatever you may tow will cause the back of the truck to balance out with the front causing an "even keel" if you will.I have had my new ranger lariat now for about 1 month. love it so far, want to level front end, i see a 2-1/2 inch kit that says it levels front , then i see a 3 inch kit that says it levels front end, besides a 1/2 inch whats the difference?
It does, not a hard thing to do with proper tools. I may go this routeGood luck with that.
This application requires the spring to be removed, correct?
I’ll order right now if you guys can hook up a deal. I like the productLet me know when you are ready we will be launching this item first in our vendor section this week with a 5G forum check out code
As mentioned with proper tools this route is typically preferred as its adding preload to the coils(similar to the way a threaded body coil over does) vs pushing the entire assembly down changing front end geometry.
PM SentI’ll order right now if you guys can hook up a deal. I like the product
Are you saying your application does not change the front end geometry? No alignment required?Let me know when you are ready we will be launching this item first in our vendor section this week with a 5G forum check out code
Please explain.
Contact Fordrangerlifts they have what you need! Very easy kit. Love mine!!I have had my new ranger lariat now for about 1 month. love it so far, want to level front end, i see a 2-1/2 inch kit that says it levels front , then i see a 3 inch kit that says it levels front end, besides a 1/2 inch whats the difference?
