FoD
Terry
Left Coast
2019 Ranger XLT FX4 Chrome Iconic Silver
Right. I read the relevant parts of that thread. The guy you quoted (as you said) used the RF woofers which have the crossover built in, and a RF supplied wire to the tweeter. We don't have that currently using stock woofer.
You may never have issues, but your tweeters may get more power that may damage them, depending on if you punching the jam :)
How I installed mine was to use red T-connectors to connect to the stock wires without cutting off the connector. Connect the crossover to the stock wires, and stuffed everything down inside the door, which fit no problem.
Tom, I installed the crossovers last week, without any change to sound quality that I can discern. At any rate, tweets are protected from my punching the jam 😉 thans
Advertisement
JeffWoodall
2021 Ranger STX 4X4
Security, Retired military (20 yrs), retired law enforcement (15 yrs)
Today I looked at Amber and smiled, thinking about how much I appreciate the fact that I was able to buy her and what she has become. My little Sabre Ranger not only gets lots of compliments, she is the fastest thing around here thanks to @5startuning and some other mods.
I've let guys from my gun club take her for drives and I still overhear them talking about her when someone new asks "who's truck is that?" The other day she was sitting next to a 250 Tremor and I actually heard someone say they would take her over that. (not looking for arguments)
I have had all kinds of awesome vehicles but she has become my favorite.
MikeyTX
Big Bend Country, TX
'21 Lariat Supercrew; '21 MX-5 Miata
Retired Military/Law enforcement
Had the bed cap installed yesterday. Today the side and rear flip window will be tinted darker. The cap is white. I'm going to have the sides wrapped in semi gloss black to match the trim on the truck. My lowering kit is on order from Belltech. My indi did that yesterday by phone. Cannot wait to lower it. WTF was Ford thinking jacking up the 2wd model ? If I wanted altitude sickness and nose bleeds, I'd of bought the 4x4. :rolleyes: :rockon::party:
JeffWoodall
2021 Ranger STX 4X4
I have screwed up so many of those things with a flat head screw driver. just be sure that if its a two piece you pry on the right part. From your initial picture, you tried the base instead of the insert and that messes them up. Know what I mean? There is a collar that goes into the hole and then an insert that causes it to swell when pushed in. You want to make sure you are pulling the insert.
Yep, true. When I changed my oil, those clips on the fender piece, were the same, and once I learned to pull up the push pin head first, then pull up the base, I pulled the rest up by hand almost.
Clump
Charlie
Frederick, MD
2019 Ranger Lariat FX4
Traded it in.
The current crazy used truck prices were too much for me. I traded for a '21 Jeep Grand Cherokee.
I have nothing bad to say about my Ranger. If not for this crazy circumstance I would have kept it.
2020 XLT Ranger scab 301A/tow 4X4 magnetic w/sport
OxyGenIII
Corey
Minnesota
New Wheels came. A little bit too aggressive for me but overall love the look. I was on the magnetic 17x8 wheels with a 1.25" spacer and 285-70-17's, and these are RRW RR7-H 17x8.5" 0 offset.
I knew ahead of time using an online calculator it was going to poke a little bit more.
Tiny amount of rub only on the driver's side when in reverse at full lock. Rubbing the fender liner. Crash bars are already removed.
My ideal offset would have been 20 but they only make this wheel in our bolt pattern in a 0 or -12 offset.
MikeyTX
Traded it in.
I understand full well. Dealer I bought the Ranger from gave me 6k more than I paid for my Mach 1. Hell yah I traded ........... :rockon: :party:
OrangeStreak
Albuquerque
2020 SCab STX 4X4 Towing Pkg./Spray in Bedliner
Retired. MTS degree. ANG veteran. 2nd Amendment supporter.
Tacos don't stand a chance :LOL:
BladeRanger
Bladimir
Escondido Ca
Ranger 2020
Electronic Engineer
BladeRanger
Bladimir
Escondido Ca
Ranger 2020
Electronic Engineer
Nice wheels and Tires Combo, what did you use to level or lift your truck?
Are this same with the ones that hold the fender flares?
The ones I mean have a Phillips head plastic screw you have to unscrew before you can pop to rivet.
Advertisement
Advertisement
