Wax did not polish all off, will it damage paint?
CB750F
Qc
Human
It was just above freezing & I decided to wash & wax the truck.
This is the first time I used ceramic turtle wax & first time I ever wax at this temperature outside.
Well, I'll never do that again. Anyway, I applied the wax , rubbed it off, it looked good but then
I noticed wax was still on. It looked 'greasy' from the side view.
Should I be concerned about the paint?
Should I just use dish soap & wash it off?
I wanted a good protection for the winter months.
Tks.
docarter
Dayton
GA
Cadillac ATS; Ford Ranger
ADA
If you haven't dirtied the truck up yet, just use a clean and dry microfiber to buff the rest of the excess wax off.
Low temps were probably the problem. Most indicate 50-80 degrees for proper application.
303 Graphane I use states cold temps may not allow it to "cure" and haze/dry...probably the same for the ceramic products.
steig
Steig
Pennsylvania
2021 Ranger Lariat Tremor
Quick detailer will remove it. No effect on paint.
Megawatt
Sin city
Unicycle.
I make electricity
Just use a steel spatula and scrape the excess off. Easy peasy. After wards you will never be bothered about excess wax on your rig.
Arizona
CEO of DeeZee
If you can get a heater and warm up your garage or maybe find a friend who has one heated. It'll make removing the wax much easier once it's warmed up. Plus you don't want t be applying any speed detailer if it's still that cold or you'll have the same results with greasy streak marks. Also use a new microfiber towel and not a used one so there won't be any residue coming off the old ones.
FoD
Terry
Out There
2019 Ranger XLT FX4 Chrome Iconic Silver
COO of Dave's DeeZee Enterprising
Do not use this method below to heat truck
;):giggle:
Trash Panda
Cody
To be honest; try this...with a ceramic product you are describing "High spots". And no, it does not damage the paint. Most SiO2 products recommend ~50+ on the temp for it to properly flash.
When it's a bit warmer, reapply the product in those specific areas and see if it "rehydrates" the high spot and it should be easy enough to wipe away.
If that does not work, since it is a ceramic product, you will have to lightly polish. And no; dawn, strip wash will not touch SiO2.
I use Adam's Polishes Graphene Ceramic Spray Coating if you ever want to try it out in the future. The above method works for it, no guarantee on other products.
Toronto, Ontario
2019 XLT SuperCab
Husband-Caregiver
Joe offers some great advice here but don’t worry about scratching your truck - your number one priority is getting the wax off - besides, you can always touch it up with this.
Like Joe and others, I’m only here to help.
CB750F
CB750F
Qc
Human
I have to say, Megawatt had a great idea & thank God Dukecanbuildit suggested
the touch up paint/method! ?
Yes, the cold was the issue, should have read the instructions.
What was in the sun polished off fine, in the shade, not so much.
Truck is filthy. No warm place.
Toronto, Ontario
2019 XLT SuperCab
Husband-Caregiver
Happy to pass on useful tips.
I washed my truck this afternoon - almost grabbed my detail spray out of habit but thought of this thread and decided it was fine without it - thanks!
