Stage3Motorsports
Diamond Sponsor
- First Name
- Joel
- Joined
- Jun 19, 2019
- Threads
- 300
- Messages
- 892
- Reaction score
- 1,361
- Location
- Phoenix Arizona
- Vehicle(s)
- 2019 Ford Ranger 4x4 XLT CrewCab
- Occupation
- Sales Specialist
- Thread starter
- #1
If anyone is in the market for a winch we have plenty in stock but check out the EVO 10-S
Message me for a discount code.
Frank
Warn VR EVO 10-S 10,000lb Winch with Synthetic Cable 103253
Warn Evo 10S Highlights:
Getting a High-Quality Warn Winch doesn't have to break your bank, and the Warn VR EVO 10-S is hear to prove it. Warn's VR EVO 10-S offers up an awesome look, compact design, and nearly unmatched reliability into a single 12V DC winch system that can handle practically any job or recovery task for your off-road vehicle of choice. This version of the Warn VR EVO Series winches is rated for a 10,000lb pull while drawing 358 amps, which makes it perfect for Jeeps, half-ton trucks, and other similar-sized vehicles. The winch comes with a standard 10x4.5" bolt pattern that allows it to mount up to most winch plates and aftermarket bumpers without any issues. The system uses a synthetic cable and hawse fairlead for a more reliable pull over competing brittle steel cables. Powerful Motor, Adaptable Controls, and Extremely Strong Case
Each VR EVO 10-S winch is built around a powerful motor and durable case that gives it awesome pulling power and unprecedented reliability. The winch utilizes a Warn series-wound 12V DC motor that combines with the winch's 3/8" synthetic rope to give the winch a total rated pulling power of 10,000lbs and pulling speed of 5.2' per minute. The VR EVO Series winch comes standard with a cast aluminum, one-piece tie plate that gives the entire winch assembly greater structural strength than tie bars. Each winch has a convertible control pack that allows for upright or low-profile mounting positions and uses a waterproof Albright® contactor to ensure excellent reliability. The winch also comes with a remote switch that uses two-in-one plug in remote for wired operation. If you desire, the remote also has wireless capability. Each winch comes standard with an aggressive black finish that gives it a great look. Warn backs each winch with a Limited Lifetime Warranty.
Winch Specs:
Frank
- Rated line pull of 10K lbs
- Fitted w/ synthetic rope & hawse fairlead
- Uses 3-stage planetary drive gear
- Features 2-in-1 remote w/ wireless capability
- Aids in off-road recovery
Winch Specs:
- Rated Line Pull: 10,000lbs
- Geartrain: 3-Stage Planetary
- Gear Ratio: 218:1
- Clutch: Freespooling
- Brake: Spring
- Mounting Pattern Width: 4-1/2"
- Mounting Pattern Length: 10"
- Rope: Synthetic. 90ft x 3/8" diameter
- Fairlead: Cast Iron Hawse Fairlead
- Bolt Pattern: 10" x 4.5"
- Remote: 2-in-1 plug in remote w/ wireless option
