unixadm
- Joined
- Feb 3, 2019
- Threads
- 10
- Messages
- 27
- Reaction score
- 21
- Location
- Sacramento, CA
- Vehicle(s)
- 2018 Ford F150
- Thread starter
- #1
TSB: 19-2197 - 2019 Ranger - Illuminated MIL With DTCs P02EE, P02EF, P02F0, P02F1, P02F2, etc...
UPDATE 06/07/19: This TSB is potentially not the solution to these issues as indicated by Ford on June 7th. Engineering is continuing to investigate.
SSM 48031 - 2019 Ranger - Illuminated MIL With DTCs P02EE, P02EF, P02F0, P02F1, P02F2 And/Or P02F3
Some 2019 Ranger vehicles may exhibit an illuminated malfunction indicator lamp(MIL) with diagnostic trouble codes (DTCs) P02EE, P02EF, P02F0, P02F1, P02F2 and/or P02F3 stored in the powertrain control module (PCM) after TSB 19-2145 has been performed. Do not attempt any further repairs at this time. Engineering is investigating. Monitor OASIS for updates.
APPLICABLE VEHICLES
2019 TRUCK: FG P375N RANGER
Original Post Below:
APPLICABLE VEHICLES
TSB: 19-2145 - 2019 Ranger - Illuminated MIL With DTCs P02EE, P02EF, P02F0, P02F1, P02F2, P050A, P050B, P0299, P1026, P02F3 And/Or P051B - Built On Or Before 26-Apr-2019
Issue: Some 2019 Ranger vehicles built on or before 26-Apr-2019 may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P02EE, P02EF, P02F0, P02F1, P02F2, P050A, P050B, P0299, P1026, P02F3 and/or P051B stored in the powertrain control module (PCM). This may be due to various software parameters within the PCM. To correct the condition, follow the Service Procedure to reprogram the PCM.
Action: Follow the Service Procedure steps to correct the condition if the vehicle meets all of the following criteria:
Warranty Status: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
- 2019 Ranger
- Built on or before 26-Apr-2019
- Vehicle exhibits an illuminated MIL with DTC P02EE, P02EF, P02F0, P02F1, P02F2, P050A, P050B, P0299, P1026, P02F3 and/or P051B stored in the PCM
APPLICABLE VEHICLES
