jblc
- Thread starter
- #1
[ I searched around online, but didn't see a direct answer on how to safely do this. Also, didn't see answers to some below questions. ]
I already have an 80 W CIGS solar panel installed on my camper shell, charging a power pack. I'm hoping to use it to continuously trickle charge the vehicle battery.
What's the preferred method to safely bring power to the battery, without risk of shorts, minimizing damage to components in case of shorts, etc?
Specifically,
(a) Should a separate ground wire be routed directly to the battery, or local ground near the battery? Or is it better to only run a + wire, and instead connect the - output to ground near the back of the vehicle where the panel's located? (since the battery "-" is already connected to ground)
(b) should the charge controller be closer to the battery, or the panel?
Two options so far:
1) solar panel -->
charge controller -->
wires under car, fused on both ends of both wires (unless needing to only route +) -->
battery
Or,
2) solar panel -->
battery
Or something else?
Specifically,
Two options so far:
1) solar panel -->
battery
Or,
2) solar panel -->
battery
Or something else?
