I’ll double check that adjuster, but i believe that it has no travel up in that position (all the way back).
Correct. I was looking for someone who has installed a modified bracket. Where to buy? I’m also not ruling out after market seats with greater adjustment. Thanks.The only thing you might be able to is use a modified seat bracket to raise up the rear.
To confirm OP your seat all the way back looses height?
Maybe shims under the frame rail in th back?Correct. I was looking for someone who has installed a modified bracket. Where to buy? I’m also not ruling out after market seats with greater adjustment. Thanks.
I think if you google seat track spacer, you will get a bunch of hits for these of various sizes. I read on another thread that a guy 6' 3" used 3/4" spacers in the rear to improve his forward vision with the seat in the fully rear position and the bolts were long enough to accommodate those spacers.Correct. I was looking for someone who has installed a modified bracket. Where to buy? I’m also not ruling out after market seats with greater adjustment. Thanks.
I literally pushed all the buttons in the dealer parking lot, then had to break out the manual to put it l back so i could drive home, lol.If the seat is too low, crank it up?
This is simple shit. Does nobody read the manual or play with stuff anymore?
