TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 45
- Messages
- 3,939
- Reaction score
- 9,888
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
One last thought on changing the fluid that might help others. I use the pump via the MBS Fitzstick to remove the fluid. I let my truck sit overnight and pull the fluid cold. I get an extra quart or so out this way. 7.5qts vs ~6qts.
The thing I noticed this time around is worth mentioning. When I changed the fluid this time I tried using FordTechMakuloco's method to achieve to proper level. Remember that I pulled 7.5qts out, so I knew exactly how much needed to go back in.
So following his procedure you pump out what you can, and put in 5-6qts, then start the truck, shifting through the gears at 10 second intervals. Then place in park, measure and top off 1 block below the hot zone (Square 5-6 instead of 4-5 when hot).
I followed the procedure adding 6 quarts initially, started the truck, then shifted through the gears. Checked the fluid and noted that it wasn't showing on the dipstick. I began adding fluid until I had it on the diamond between 5 and 6. Total fluid req'd 7.5 quarts! It worked! Drove the truck and noticed a couple of mild issues, adding another 6oz of LubeGard Platinum (swapped fluid for LGP) and took it for another spin, smooth as silk.
This morning (41F) I measured the fluid level going through the same "start the truck shift protocol" and checked the fluid level. It barely registered on the dipstick, not making it past the bend at the tip. Not sure why it was reading so low.
Thinking maybe I did something wrong I added 1/4 qt to get it back on the diamond between 5 and 6. Test drove it 75 miles ( I am sure I did not reach the 206F-215F temp window, got home and checked the fluid level. This time it registered at the diamond between 4 and 3! One full block too high. There was no foaming or overflow, but the fluid level was clearly too high, and I pulled the 1/4 quart out. This dropped the level to just above 5.
I have no explanation as to why the fluid level varied so much after the test drive and sitting overnight.
Anyone one else notice this much difference in fluid level after a initial fluid change?
On another note, I am going to look at this a little closer to quantify the expansion range of the fluid at ambient temps. The goal for me is to find the overnight cold static spot on the dipstick to fill with temps at 40F, 60F, and 80F, etc. I'll keep the truck at the same spot (level) when measuring. One of the benefits is the oil is much easier to see on the dipstick when cold and settled overnight.
During fluid changes, I will continue to replace the exact amount I take out, but will validate the next morning with a static cold reading.
it's more fun sounding than MBS RS-1023
