machinist85
- Thread starter
- #1
Can you LINK us that wayIf you are wondering the dip stick from B&M will work. One of the other members on here has already installed one on his ranger. Also there are a few companies that have a transmission pan with a drain plug(PPE is one of them) where you can do a drain and fill without having to worry about changing the filter.
Just go to the transmission service thread. The information is there.Can you LINK us that way
Are you referring to these?If you are wondering the dip stick from B&M will work. One of the other members on here has already installed one on his ranger. Also there are a few companies that have a transmission pan with a drain plug(PPE is one of them) where you can do a drain and fill without having to worry about changing the filter.
So I haven't seen the first one but yes those are what I'm referring too. The nice thing is the 10R80 pans are identical across the board. It just comes down to space for fitment.Are you referring to these?
https://www.ppepower.com/shop/heavy-duty-cast-aluminum-transmission-pan-ford-10r80-trans.html (Generic 10R80 Pan)
https://www.ppepower.com/shop/heavy...ansmission-pan-2017-ford-f150-with-10r80.html (1.75 quart upgrade 10R80 Pan)
I haven't seen that many aftermarket corps making transmission covers. I really like Gale Banks Rear Differential cover, although I've seen videos of them rust like everything else out there (they don't make one for the ranger). Here's to hoping my Dynatrac.. er.. I mean "Ford High Performance" rear differential cover lasts a long time.
Hey, I also found this awhile ago;So I haven't seen the first one but yes those are what I'm referring too. The nice thing is the 10R80 pans are identical across the board. It just comes down to space for fitment.
What I dobt like about that particular model is the cooling fins are lacking a bit. When changing the pan I prefer to add the ability to cooling capabilitiesHey, I also found this awhile ago;
https://yourcovers.com/transpan_11164.php
I wonder if they'll offer a more competitive price on their version. (If it ever comes out!)
