Towing with a Tremor
Dakota
2022 Ranger Lariat Tremor
Anyone done any towing with their Tremor?
I am going to tow my Polaris RZR on an aluminum trailer.
What can I expect?
newtremorguy
Ryan
Seattle, WA
Dad stuff
I tow a 17' ft Boston Whaler with two engines, main and kicker, with galvanized trailer and the Ranger pulls it effortlessly. More importantly, though, is I launch/retrieve it on a very gravely/pebble steep beach without any drama. My 2018 F150, which also had a locking diff, had more problems getting off the beach than the Ranger. In the F150, I had to regularly air down the tires to make it work. The Ranger hasn't put up any fuss and plows through it.
Well let's see here.
The Tremor Package still has a max tow rating of 7,500 lbs if equipped with the tow package(3,500 without). If your Polaris and trailer are within said towing specifications you should expect to tow just fine.... Unless you do something stupid.....
Other then that its all I got!!
Ranger Sam
Samuel
Utah
2021 Ford Ranger XLT Tremor
What can I expect?
I just used my '21 Ranger Tremor to move from the Salt Lake Vally in Utah to Idaho Falls. For my move, I rented a 6 x 12 ft enclosed Uhaul trailer. I was a little worried because I was hauling up my heavy workbench with tools, a washer and dryer, couch, and full bedroom set. the tremor definitely squatted a bit, and it looked like it was resting on the bump stops, but I didn't think to measure the squat. I left early in the morning to attempt to avoid traffic as much of the 240-mile drive is on the freeway with an 80 MPH speed limit. I was very gentle for the first hour, but became very surprised at how well the trailer towed. I was trying not to go over 75 mph, but by the time I got to Pocatello, I was driving 85-90 mph. I could not be more astonished at how the truck handled. Yes, the truck did spend more time in the upper rev range, but I never felt I had a lack of power. I had no trailer sway at all and felt very safe the entire time. With myself and my brother in the truck with me as well as a bed full of other stuff I'm sure we were either right at, or above the max payload but all went well.
The Uhaul trailer did have trailer breaks which did help.
I would not be worried at all about towing your RZR.
bentroia
Ben
Auburn CA
2021 Ranger Tremor
Logistics
You're obviously skilled.
ControlNode
Eastern NC
Computers
May want to watch the speed, owner's manual states to not exceed 70mph while towing. I set the cruise at 70MPH with the adaptive at max gap when speed limit is >=65MPH.
Ranger Sam
Samuel
Utah
Yeah I started out keeping it 70, but the speed limit is 80 and most people go around 85, so driving 15 mph slower than everyone was a little scary. I'm almost positive the only reason the owners manual states 70mph is because the ranger doesn't have trailer breaks. The engine or transmission didn't seem any more labored than usual.
Something to also consider is general vehicle safety and the fact that Ford does not want to be held liable if you go too fast.
Yes the Ranger is plenty capable but when towing the best thing to do is take your time to get the job done safely
Stic-o
Lake View Terrace, CA
You'll be fine. I have towed everything from travel trailer, to car carrier with a Explorer on it, to a skip loader. Some of these I have towed as far as South Dakota from Los Angeles.
No problems, truck doesn't care and this always been with a 2.5" lift on 33's.
Everyone is always amazed at it's capabilities.
Dakota
What kind of mileage did you get when towing?
ControlNode
Eastern NC
Computers
Well, if you don't have trailer brakes I think the max tow load rating is 1650lb according to the owner's manual, yes I know the U-Haul trailer includes surge brakes. Trailer brakes are an option that can be added and my manual does not state that with the brakes the 70mph limit can be ignored. As for why there is 70 limit to start with, I can't say why, could be the trailer sway control programming was found ineffective over 70mph at recovering a sway. But operating a vehicle outside what the manufacture states it should be could make you liable for any issues that happen, whether its just wear on the vehicle or a wreck.
Also, while I'm towing I often select the avoid freeways option in my navigation app for areas with speeds over 70MPH. I agree I would not want to have a 15 MPH difference from the rest of traffic.
pbethel
Patrick
kingman az
Most trailers come with tires rated for 65 MPH.
They are cheaper.
Definitely watch the speed rating on the tires both truck and trailer. Also, you will find that your mileage will go in the tank badly after 65-70 mph. With the small tank in the ranger gas stops come soon enough. Especially with a box trailer or TT the frontal area is a killer. I know the speed difference is scary, but stand your ground, stay in the right lane and let them go. Somebody doing 85-90 you don't want to be around anyway. My policy towing my TT is 70mph max.
