Should this be done if you change tyre size? Whats the impact on the vehicle?It can be changed using Forscan.
I have not changed tire size nor used forscan. I presume that the only impact is less mpg.Should this be done if you change tyre size? Whats the impact on the vehicle?
I'd be keen to know. I think you might be rightI have not changed tire size nor used forscan. I presume that the only impact is less mpg.
What module and address did you change?Forscan let's you change a ton of options in your truck like lighting delays, digital appearances, chimes ect...
I used it to change my tire size so my mpg, speedo and trip computer would be accurate. It is nice to know when your rig says you are going 65, you are going 65
