Tie Rods
SimonSaucy
simon
Uniter States Las Vegas
2021 ford ranger STX
engineer
So in the process of doing my lift kit. I noticed my outer tire rods are pretty shot. And the inner ones are not holding their position so looking to replace them.
Call the dealer to try to order the parts. But it looks like they can’t get the left tie rod end, it’s back ordered for the next few months.
Is there an actual difference between the right and the left?
I can source the inner tie rod end from Ford. Should I look at aftermarket for the outer? Or should I go aftermarket for everything? If so, what brand would you recommend from rock auto
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
They are definitely different. All cars are. Some back in the day were reverse threaded, now more common are small angles and off sets. They mirror each other. Go with a good aftermarket on rockauto. The green brand is actually pretty good. Ttx I think its called. Made for severe use and off road.
Superspirit
earth
22 ranger
Moog all the way, they usually have a superior part. They also have a problem solver series of parts to address shortcomings in the OE parts.
Superspirit
earth
22 ranger
If you have a steel knuckle, good luck! I’ve tried 3 different parts(1 Ford, 2 aftermarket), none fit!
What parts were they that didn't fit, brand, part number or description would be helpful just saying parts don't fit doesn't help anyone.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
I have a steel knuckle. Got some free unused outer tie rods and they fit perfectly. Never really wondered if they fit or not. They were ford OEM ones
COblue
Ross
SLC, Utah
Blue Ranger Lariat, bone stock
Replaced mine recently with all Ford parts and no issues.
Unfortunately the switch to aluminum knuckles happened midway through the build year so you have to check your build date on the door handle. Or just order 2019 parts rather than 2020. Parts guy had some issues getting the computer to agree that it would fit.
RealRigsRattle
Tim
Mesa, AZ
2020 Ranger Lariat FX4
Ford MEF521/MEF519, Delphi TA3615/TA3614 wrong stud size, correct length. Tried one from O’Reilly but can’t find the part#. I have a mid-2020 with steel front knuckles.
