MountainGoat
- Thread starter
- #1
Title says it all. Trying to narrow down the issue if that's possible.
SSM 49264 - 2019-2020 Ranger - Climate Control Temperature Will Not Adjust With Clicking/Snapping Noise From The Dash - Built On Or Before 30-Jul-2020
Wow I'm at August 2020SSM 49264 - 2019-2020 Ranger - Climate Control Temperature Will Not Adjust With Clicking/Snapping Noise From The Dash - Built On Or Before 30-Jul-2020
Made it by one day.Wow I'm at August 2020
I guess I'll leave the poll up? In case Ford's dates turn out to be BS.
For some reason I don't think I'm totally in the clear just cause Ford says the problem stopped on July 31st.Made it by one day.
Only one issue, we're still king of the hill. lolOh no. Should someone start a thread, "Are '19s really built flimsy?"
Do you have the dashboard rattle or is your passenger seat belt clanging against the pillar? Many have these issues.Mine is a 21 and if I set it between 70 and 80 it makes noise constantly.
The seat belt clanging against the pillar gets me everytime. lol. Once I realize its just the belt, I let out a big "WHEW" ?Do you have the dashboard rattle or is your passenger seat belt clanging against the pillar? Many have these issues.
Sest belt does bang around a bit. Easy fix. Dash does have a bit of noise over the guages, but the blend door actuator definitely clicks. Im probably going to replace it myself. Last F150 was a dash out replacement. I did it in 30 minutes. So ill try it again.Do you have the dashboard rattle or is your passenger seat belt clanging against the pillar? Many have these issues.
