Third Brake Light for Softopper
BcP28
Bennett
2021 Ford F150, 2015 Ford Edge Sport
Recently added a Softopper to my Ranger. Love the top so far, but am concerned about the lack of third brake light. I realize this probably isn't that big of an issue, but I'd hate to be a victim of someone texting and not able to recognize my brake lights, or a LEO having a bad day, so figured this was an easy solution.
I ordered an inexpensive red LED light strip from Amazon that comes with 3M adhesive tape attached. These lights seem to be good quality, weather resistant, are bright, and have low power consumption (I measured 34mA at 12.8V).
https://www.amazon.com/gp/product/B01GRO844G/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Next I had to figure out where to tap into for a clean brake light signal. The Ford Body Builder guide shows a tap in the fuse/relay panel in the driver's side footwell, but I didn't see a clean and easy wire path there, so I started looking into the tail light harnesses to see if there was a good tap. The LED tailights on my XLT have individual signals for the brakes, tails, and turns, so that looked like a good source. Pin 2 is a dedicated brake signal that is 12V, so that should work! This is the driver's side tail light.
Here's the harness disconnected from the taillight. The wire you want is the red one, at least on my truck. I used a simple wire tap. I'm not a huge fan of these, but it was easier than disassembling the harness to get a cleaner splice, so we'll see how it holds up.
I placed the light itself in the center on the rear flap. It seems to stick pretty good to the canvas. I ran the wire along the rail and over to near the tail light area. There is a hole in the bed under the rail that is good access to behind the tail light, so that worked perfectly.
I used a waterproof connector here so that I can quickly disconnect if I ever want to remove or fold the topper.
And here's the finished product. No rapid flashing lights, or flashing with turn signals. Seems to work well.
BcP28
BcP28
Bennett
No issues yet. It's pretty well protected behind the taillight and seems to be holding up pretty well.
CoolMoose
Daniel
Iowa
Software Engineer
How did you ground the LED strip? Did you tap that as well? Thanks!
BcP28
BcP28
Bennett
Haha it's been long enough now that I'll have to go and look to remember what I did! :LOL: I'm pretty sure I just grounded to chassis. There should be a bolt somewhere behind the taillight I used. I'll pop the tail light out this evening and confirm.
Nopalito
Richard
21 Cactus Grey XLT
Emergency Manager
I plan on doing this when I get my softtopper. Thanks for writing this up!
CoolMoose
Daniel
Iowa
Software Engineer
FYI - I tapped the ground wire in the same plug shown above. Was last minute before my trip so I couldn't come up with a more 'secure' solution, but it held up to my mild offroading trip!
r2ranger
CA
Thanks writing this up! Just ordered my soft top and this is exactly what I needed to figure out how to properly tap in. Just glad Ford kept it simple on the color coding for hot and ground.
ScrappyLaptop
Scrappy
SF Bay Area
2020 Ranger XLT SuperCrew 2x4
IT
hows that tap holding up?
Those blue crimp-taps really aren't bad for correctly sized solid core wire, sort of like a phone or network punchdown block. Vehicles use stranded though.
A trick I learned years ago from a U-Haul tech in the 90's: The weatherproofing can be very much improved by popping them open and squirting a small blob of dielectric grease in the middle.
Ideally, wrap it in self-sealing tape after.
Bluestem
Capron, il
'19 Ranger
Which one of those wires would you tap if you wanted to add a third brake light with a tailight wire as well? TIA.
Bluestem
Capron, il
'19 Ranger
It would be the running light. The 3rd brake light I'm looking to add on my topper has a brake light wire, a tail light wire and a ground.
Terra Rover
Oklahoma
2022 Ford Ranger Tremor
Just FYI, this post was exactly what I needed to setup the brake light on my GFC topper. GFC supplies the correct taps for stranded wires. Thanks!
Lcr3000
Craig
Alexandria
Ranger Tremor
IT Engineer
This also works for the third brake light built into a sport/rollbar. The red #2 and the black #10 for ground worked fine for me. No issues.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Nice. This is a good idea, thanks for the info. I got a Flated inflatable topper and this could work.
