Things you did not know
SandBaja
Larry
San Diego
2019 Silver FX4, 501A pkg, fully optioned,2012 Rubicon, 2017 Cherokee, 2018 Volt
Almost retired
When off-roading in the sand auto high beams do not activate automatically. This applies to dry sand, not wet. If the sand road is darker due to oil or water compaction treatment it should activate. My working theory is the sand is reflective back to the camera.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
The 2.3 is the same of a 70’s Pinto just direct injected and a turbo slapped on.
fusseli
EE
Displacement and cylinder count are the same, engine is quite different. I have a turbo Lima and the new, unnamed, 2.3 in the Ranger
HenryMac
Mech. Engineer - Retired
Traneman
Jay
Rochester MN
2019 Ford Ranger STX 4x4
I had a '93 and I was blown away when I saw 2.3 was changed the ignition utilizing a new 8-plug. When I told people it had 8 plugs they were puzzled why, and I never knew why they did? I will say, the thing ran really smooth and quiet for a 4 banger!
Hi Jay,
The twin plug 2.3L was launched to improve combustion efficiency by establishing two flame fronts in the combustion chamber. There was a slight power gain in the motor, but really for emissions reasons. I kept joking to Engineering that while other manufacturers doubled the number of valves in the engine, ie 4 Valve cylinder heads, Ford chose to double the number of spark plugs.
Ford Motor Retired
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Hi Jay,
Ford Motor Retired
I don’t know how popular it is to have 2 spark plugs per cylinder on cars anymore but many V-Twin motorcycles still have them
DHMag
Dale
San Antonio, TX
Hi Jay,
Ford Motor Retired
Years ago on another Ranger forum, a guy turned the 8 plug ignition into a primary and secondary ignition. There were power gains but I don't know how much. I imagine it would be like the secondaries opening on the SHO or a 4 barrel carburetor.
FULLSCALE
Adam
Ontario, Canada
Not sure if either still do but some of the 5.7L Hemi and the Ford 6.2L have 2 per cylinder.
Rinn69
N. Central Iowa
Retired USAF MSgt
There, they're, and their are 3 different words and are not interchangeable.... :LOL:
Mokume
Honolulu, Hawaii
Hi Jay,
Ford Motor Retired
Nissan (Datsun) accomplished the same with their line of "Naps-Z" 4 cyls. from the early eighties. These were well known for their durability and did not suffer from headgasket issues that the "L" series of engines were infamous for.
My brother owned a beater '82 Nissan pickup which he bought for $50 in the early nineties, the reason why it was so cheap was that the body had rust holes big enough to stick your fist through, he must of slathered gallons of "Bondo" on that thing. Not sure if they were still called "Lil Hustlers" back then, but the rot that poor thing had done tremendous amounts of "hustling".
Body rot aside, that little 4 banger ran like a top, 8 spark plugs and all.
