Swing case with bed mat
r2ranger
CA
Does anyone on here have the bed rug impact mat installed with a swing case? Any issues with the fitment? The rubber mat is about an inch thick so I’m worried the case won’t clear it? Thanks! ??
Wouldn't worry at all...
I have the box with a sprayed in liner, and there's almost 2 inches from box bottom to bed floor.
I have the full Bedrug liner in mine with cases both sides. Plenty of clearance.
r2ranger
r2ranger
CA
Awesome! Thanks!
taildraggerpilot
Carl
Kennesaw, GA
2020 Ranger Lariat FX4, 2022 MINI JCW Hardtop, 1967 Mooney M20E
Boeing Guppy Driver
You’ll be fine. I have the same setup. Just take your time tapping the mount holes. Bed liner spray needs to be removed out of them. Also, be careful to cut the edges of the liner away from the tie down hook(s) as you will need to temporarily remove them to add the box. It’s a nice accessory.
DoctorsTARDIS
Ohio
2021 Ranger Tremor
Tako
The Valley
None
Have one sitting at my dealership for pick up. For those without a bedcover: Has anyone had problems with theirs (warp, cracking, discoloration)?
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
I have the Ford bed mat and the swing case and no issues at all.
OHTREMOR
Ohio
2021 Ranger Tremor
I have rhinoliner, and a bed mat and they have lots of clearance
I got the knock off boxes off eBay and they are basically identical, but half the price. The only issue with them was that I needed to provide my own mounting hardware as the stuff it came with was completely wrong. It needed 3 M6 1.0mm thread pitch bolts.
https://www.ebay.com/itm/Rear-Passe...2349624.m46890.l49286&mkrid=711-127632-2357-0
You still happy with the function and quality of these? May throw one in really like the savings if it is up to par with the swing case or own. thanks
gwhalin
Greg
New York
No clearance issues with liner and a rubber bed mat.
However, starting to have to really pull hard on the release to get it to swing loose. Anyone else experiencing this? May hit it with some lubricant to see if that helps.
Langwilliams
Langley
Lorain, Ohio
yes sir, no issues
The only possible issue is if you have the wing nut style clamps. I had to trim the one down that's over the box.
here's the on one I didn't have to shorten so you know what I'm talking about.
VegasRanger
Las Vegas
Damper Salesman
Oh yes! You are 100% correct. I did have to trim one of mine down as well now that you mention it. I had forgotten about that. Was a quick job with my dremel.
