PierreD
From etrailer...Curious to see how you guys with sumos or timbrens still like them. I've never messed with my suspension before but since I tow close to max payload and tongue weight I figure installing aftermarket springs might help stability and suspension longevity.
I'm close to buying the sumo springs but go back and forth on if I should do 1000lb or 1500lb...hmm. I often tow a 5500-6000lb trailer with 650-750 loaded hitch weight and maybe 100lbs in the bed forward of the rear axle. Any reason to go to the 1500lb springs?
Is There Any Advantage in Using SumoSprings With Weight Distribution on a 2016 Toyota Tacoma
Question:
have a 2016 toyota tacoma and tow a 23ft travel trailer 4770 lbs. I currently have to weight distribution hitch and trailer and truck are pretty level. My question is their any advantage for adding the the sumo springs?
asked by: Shawn Y
Expert Reply:
Even though the Super Springs SumoSprings # SSR-610-40 will help to keep your 2016 Toyota Tacoma level while towing like a weight distribution system, they are meant to keep your Tacoma from experiencing too much wear and tear while under a load. They can be used with or without a weight distribution setup, and will improve your rear suspension either way. A weight distribution system is geared towards making your whole towing setup more level and safe, where the SumoSprings are a little more focused on your Tacoma.
I recommend adding suspension enhancement, like the SumoSprings, even if you are already using a weight distribution system, to help extend the life of your suspension and to give yourself a more comfortable ride.
