Step Bar Filler Panels or touch up rocker panels... or is this a warranty claim for sloppy paint job?
paval3
Val
Pennsylvania
So I was just looking at the rocker panels on both sides of my Ranger that I just got last week. I was walking by the truck, and I notice the bottom of the rocker panel looked rough on the driver side. I compared it to the passenger side. Upon closer inspection, it looks like a bad paint job along the bottom with globs of paint. I ran my hand along the length, and some paint fell off in a couple spots. I got down and looked under the truck and yep, bare metal on the bottom edge of the rocker panel where the paint globs (about 3/4inch wide each) fell off!!
Is this something I should bring to the dealer's attention under warranty? I first thought, oh well I can prep it and touch it up and then have the step bar filler panels installed. Well, I looked at the price for those... gulp. And then they only come in bright stainless steel and my truck has the black appearance package.
Kinda gripes me that this truck got through quality control with a paint job like that. Should I just touch it up myself and live with it and hope it doesn't eventually start rusting there?? I waited 18 years to buy a new vehicle again, so you can imagine how I might feel.
spartan0078
Ontario
2021 Ford Ranger lariat
Railroader
The paint is supposed to be more rough along the bottom of the rockers for added protection. But it certainly shouldn't be falling off.
paval3
paval3
Val
Pennsylvania
The passenger side is smooth if you run your hand along the bottom, nice clean paint job. The driver side has globs of paint, looks like paint dripped and dried in paint globs and flake off easily by running hand along bottom edge leaving bare metal. You have to get down and look at the bottom edge to see the bare paint. I could live with the sloppy paint job visually, but worried about bare metal may rust where it flaked off.
I did just see these. What do you all think... if I touch up the bottom edge and put something like these on?
https://www.bushwacker.com/Truck-Trail-Armor-Rocker-Panel/2021/ford/ranger
jmurph
jake
Alaska
2021 XLT Ranger
Gov
Guessing it's like mine only noticeable if you stand a few feet away or take a knee next to the truck
paval3
paval3
Val
Pennsylvania
Yes, but my paint drip globs are even bigger I do believe! Is yours flaking off?
jmurph
jake
Alaska
2021 XLT Ranger
Gov
If I touch them they will definitely peel right off with a poke, but otherwise seem to be fairly hard and sealed on the pinch weld
paval3
paval3
Val
Pennsylvania
got a camera?
I have an older iPhone with not the best camera, but I can try to take a pic tomorrow of the outside edge. I know I can't get a photo of the lower edge underneath where there is now bare paint from the globs flaking off.
paval3
paval3
Val
Pennsylvania
Maybe I should just order the touch up paint and address the bottom edge that way for now then keep an eye on it. If the globs flaking off start taking paint from the outer edge where bare metal would be visible, I'll have to do something else like adding those Bushwackers on.
jmurph
jake
Alaska
2021 XLT Ranger
Gov
Honestly might be better to just get some clear coat and cake it on and seal it up good.
paval3
paval3
Val
Pennsylvania
That would be easy enough.
peterson1604
Scott
Escanaba, MI
Body shop manager
The rockers should be rough on both sides. They apply a product called gravel guard to protect against rock chips and then the gravel guard is clear coated over for added protection. Chances are the dealer has a body shop that can take care of this under factory warranty so I would certainly get it addressed.
If your roads in Pennsylvania are salted like our roads in Michigan during the winter you're going to want this taken care of to protect the metal.
Langwilliams
Langley
Lorain, Ohio
I was thinking of painting that area black. I think it would blend in with the frame an look better.
paval3
paval3
Val
Pennsylvania
Are you talking about a very slight pebble type texture to the paint? I've seen that, but that isn't what this is. When I say rough, I don't mean the paint finish texture, I mean like rough uneven edge at the very bottom because it's like globs of paint hanging down and when you touch them they flake off leaving bare metal.
peterson1604
Scott
Escanaba, MI
Body shop manager
Correct, tough to tell what your issue is without seeing a good picture but you should still bring it into the dealer since it's under warranty.
