I went with the factory spray-in. Probably not the cheapest but I am pleased with the result.Should I go with Ford for the Spray-In? Would you suggest a Spray-In? does this limit me in anyway for mods/racks, etc...?
Also, is there an alternative to the plastic guards on the bed?
Thank you!
If you already have the truck, I don't see how you can get factory. Instead you'll be at the mercy of the dealer to pick a local. And it seems that who you pick is more important than the brand, with application technique varying. You might check on Bullet Liner dealers in your area, from the little I saw.Should I go with Ford for the Spray-In? Would you suggest a Spray-In? does this limit me in anyway for mods/racks, etc...?
If you want a liner you don't have to worry about then the spray in is the answer. If the truck you are buying has the factory one then you are set. It not, go with Line-X and spend the extra on the premium with UV protection. Well worth the money. Just my .02 on spray in liners since you asked.Should I go with Ford for the Spray-In? Would you suggest a Spray-In? does this limit me in anyway for mods/racks, etc...?
Thank you!
My uncle has one on his F150 and it does not fit as well as yours. That looks really nice!!!If you already have the truck, I don't see how you can get factory. Instead you'll be at the mercy of the dealer to pick a local. And it seems that who you pick is more important than the brand, with application technique varying. You might check on Bullet Liner dealers in your area, from the little I saw.
Personally I decided to try a BedRug. Still had my rewards points to spend, so it was less than $200 shipped from fairwayfordparts.net. Nate makes it real easy too, providing a quote via email that has a link to purchase. I had it in under a week.
