Safety Recall 19S43 - Select 2019 MY Ranger Vehicles Rear Lamps Issue
Discussion in 'Issues, Repairs, Warranty, TSB, Recalls' started by Beef_Stew, Nov 22, 2019.
Tags:
  1. Beef_Stew
    Beef_Stew Well-Known Member
    First Name:
    Aaron
    Vehicle(s):
    Aug 16, 2018
    USA
    237
    188
    NEW VEHICLE DEMONSTRATION / DELIVERY HOLD
    Safety Recall 19S43
    Select 2019 Model Year Ranger Vehicles
    Rear Lamps Issue
    Affected Vehicles:
    Vehicle: Ranger
    Model Year: 2019
    Assembly Plant: Michigan
    Build Dates: June 4, 2018 through August 16, 2019
    Reasons for this Safety Recall:
    In some of the affected vehicles, terminals in connector C422 may be misaligned and may have been damaged during assembly. If a misalignment occurs and terminals are pushed out, there may be a loss of functionality of both the left and right rear tail lamps. While the center high-mounted stop lamp (CHMSL) will continue to function ensuring some level of stop lamp indication, all rear tail lamp features will not function. This includes the stop, turn, rear position, and reverse lamp features. This condition may be intermittent.
    The C422 connector is a 34-pin inline connector and is located on the 14290 to 14405 harness mounted to the left frame rail around mid-vehicle.
    Service Action:
    Before demonstrating or delivering any new in-stock vehicles involved in this recall, dealers are to inspect connector C422, checking for any terminal push out, and if necessary replace the hard-shell connector. Simultaneously, a continuity check will be performed on the ground circuit, from the tail light to connector C422. This service must be performed on all affected vehicles at no charge to the vehicle owner.
    Owner Notification Mailing Schedule:
    Owner letters are expected to be mailed the week of January 6, 2020. Dealers should repair any affected vehicles that arrive at their dealerships, whether or not the customer has received a letter.
    Download Ford Service Manual for Inspecting and/or Replacing Rear Stoplight Pigtail (EXTREMELY LARGE PDF WARNING)
    Do You Get A Rental Vehicle If You Are Affected By This Recall?
    PASS INSPECTION: Vehicles that pass inspection are NOT affected and are not approved for rental vehicles. Refer to the 19S43 technical instructions for additional information.
    FAIL INSPECTION: For vehicles that fail inspection and the applicable wiring pigtail kit is not available, submit a VIN-specific contact, along with a photo of the hard-shell connector showing terminal push out, via the SSSC Web Contact Site.
    • A ten-digit approval code is required from the SSSC for rental vehicles.
    • If rental vehicles are needed beyond 1/3/2020, dealers will have to contact SSSC for an extension.
    • Part orders will be taken, but will be held by SSSC until sufficient quantities are available, which is expected by early January. Approval for all rental vehicles for this program will end at that time.
    • Follow Extended Service Plan (ESP) guidelines for dollar amounts. Prior approval is required from the SSSC.
    Courtesy of @Willcuts93
  2. joeb427
    joeb427 Well-Known Member
    First Name:
    Vehicle(s):
    Feb 11, 2019
    922
    954
    Occupation:
    Garage Profiles:
    RECALL
    REAR TAIL LAMPS
    NHTSA Recall Number: AWAITING# NHTSA Date:NOV 21, 2019 Ford Recall number: 19S43
    Status:12 - RECALL INCOMPLETE. REMEDY NOT YET AVAILABLE.
    Recall Description:REAR TAIL LAMPS
    Risk to Safety:INTERMITTENT OR INOPERATIVE TAIL LAMPS CAN RESULT IN LOSS OF STOP, TURN, REAR POSITION, AND REVERSE LAMP FUNCTIONS, WHICH REDUCES THE VEHICLES VISIBILITY AND MAY NOT FULLY ALERT OTHER DRIVERS THAT THE VEHICLE IS BRAKING, TURNING, OR REVERSING, INCREASING THE RISK OF CRASH. THE CENTER HIGH-MOUNTED STOP LAMP (CHMSL) WILL CONTINUE TO FUNCTION.
    Remedy Program: OWNERS WILL BE NOTIFIED BY MAIL AND INSTRUCTED TO TAKE THEIR VEHICLE TO A FORD OR LINCOLN DEALER TO HAVE THE UNDERBODY INLINE CONNECTOR INSPECTED. IF A LOOSE TERMINAL IS IDENTIFIED, THE TERMINALS WILL BE RE-PINNED INTO A REPLACEMENT CONNECTOR. THERE WILL BE NO CHARGE FOR THIS SERVICE. FORD IS EXCLUDING REIMBURSEMENT FOR COSTS BECAUSE THE ORIGINAL WARRANTY PROGRAM WOULD PROVIDE FOR A FREE REPAIR FOR THIS CONCERN. FORD WILL FORWARD A COPY OF THE NOTIFICATION LETTERS TO DEALERS TO THE AGENCY WHEN AVAILABLE.
    Manufacturer Notes:TO CHECK FOR NON-SAFETY-RELATED PROGRAMS APPLICABLE TO YOUR VEHICLE, SEE HTTP://WWW.FORD.COM/ OR CALL YOUR FORD DEALER.
  3. RANGER PRIDE
    RANGER PRIDE Well-Known Member
    Vehicle(s):
    2019 Ranger FX4 Supercrew
    Sep 4, 2019
    Vancouver
    633
    496
    mine as well.
    my lights have never given me a problem though
    u wish u could ride likes this.
  4. joeb427
    First Name:
    Vehicle(s):
    Feb 11, 2019
    922
    954
    Occupation:
    Garage Profiles:
    Me neither.
    2/19 build date.
  5. Sabasigh
    Sabasigh Well-Known Member
    Vehicle(s):
    2019 Ranger Lariat FX4; 2016 Corvette Stingray
    Aug 17, 2019
    Belleville il
    111
    68
    t4thfavor likes this.
  6. joeb427
    First Name:
    Vehicle(s):
    Feb 11, 2019
    922
    954
    Occupation:
    Garage Profiles:
    There's no fix yet on the recall.
    Everything working ok now?
  7. Sabasigh
    Vehicle(s):
    Aug 17, 2019
    Belleville il
    111
    68
    Yeah, i put on a bunch of miles in the last 2 mos and so far so good. From my ticket, i thought there was an updated/replacement harness available.
    joeb427 likes this.
  8. Schafies
    Schafies Well-Known Member
    Vehicle(s):
    2017 Ford Explorer. 2019 Ford Ranger.
    Aug 28, 2018
    Indiana
    199
    77
    I have not had this issue but might print that recall out and put in my truck in case I have the issue and don't know a tail lights out and get stopped by the police! Might help, might not? To the few here on this forum that have had tail light issues does the truck alert that a tail light is out, or both are out? Or is the alert the flashing lights on the car behind you. Lol
  9. dguffin
    dguffin Well-Known Member
    First Name:
    Dana
    Vehicle(s):
    19 MKC, 19 Ranger, 12 Boss, 08 Zuma
    Nov 4, 2018
    Aberdeen, SD
    69
    48
    Occupation:
    Shop Foreman
    Garage Profiles:
    Recall letters from Ford will start going out in January for this recall.
  10. OP
    Beef_Stew
    First Name:
    Aaron
    Vehicle(s):
    Aug 16, 2018
    USA
    237
    188
    Just browsed over the recall. Pretty much all it is, is just checking a wire harness plug under the vehicle to confirm the pins are secure and not damaged or loose. If they are, it is a terminal pigtail replacement.
    joeb427 likes this.
  11. Sabasigh
    Vehicle(s):
    Aug 17, 2019
    Belleville il
    111
    68
    You get the fast blinker sound inside the cab like you have a bulb out...that's how i found out.
  12. Schafies
    Vehicle(s):
    Aug 28, 2018
    Indiana
    199
    77
    Thanks for that info.
  13. Rp930
    Rp930 Well-Known Member
    First Name:
    Vehicle(s):
    MB, 69 Camaro
    Nov 19, 2018
    Denver
    304
    190
    Occupation:
    I’m in this one.
  14. I_smell_like_diesel
    I_smell_like_diesel Well-Known Member
    First Name:
    Vehicle(s):
    2019 Ford Ranger FX4 Lariat
    Sep 2, 2019
    Gregory, Michigan
    161
    156
    Occupation:
    Master Mechanic and Fabricator
    Thanks for sharing this.
  15. P. A. Schilke
    P. A. Schilke Well-Known Member
    First Name:
    Vehicle(s):
    2019 Ranger FX4 Lariat 4x4, 2016 Lincoln MKX, 2005 Alfa Motorhome
    1,298
    2,764
    Occupation:
    Garage Profiles:
    Hi Folks,
    I would really like to understand the Ranger electrical connectors. I have never seen a North American Ford vehicle with such connectors. I wonder if these connectors are from Thailand. My opinion is that they are not robust for assembly and have been the bane of a multitude of electrical problems. Since I have not looked at any other North American Ford products to see if they have the same style of connectors, I can't determine if Ford globally changed the electrical architecture of the electrical system or are we dealing with unique Aussie designed electrics? Any Ford Dealer mechanics on board that can shed some light on this Ranger electrical system compared to the North American products.
Share This Page
