SpifNup
- First Name
- Spif
- Joined
- Feb 13, 2023
- Threads
- 1
- Messages
- 10
- Reaction score
- 28
- Location
- Pittsburgh, PA
- Vehicle(s)
- 22 Ranger XLT 4x4 Crew 5' Bed 2.3 ECO
- Thread starter
- #1
22 Ranger XLT SCrew 4x4 Oxford White
At purchase, bought and trimmed 1x2 length from Lowes to prop rollup garage door above frame.
Sized down roof antenna with 4-inch 'stubby' replacement.
Allowed safe entry & especially backup exit from garage without catching roof antenna.
Unfortunately (stupid me) didn't untie small rope pull loop fastened to center hinge on door.
[Thought of it several times, but didn't seem to be a problem (for whatever reason ant never got stuck in the rope loop). Then forgot about it! ]
Couple nights ago, parked too far left in garage. Needed to clear swing of normal door. Backed out to re-center & re-park.
During backing, stub caught on rope loop (hangs down about 14 or 15-in from center of rolled up door).
Bang noise, then wood prop dropped.
Quick glance (night time) saw no antenna damage.
Closer look in daylight today reveals antenna/roof damage as follows:
--Black plastic antenna base now loose & wobbly.
--Can finger raise to 1/2 or 5/8 inch above roof.
--Slight hollow now (only visible roof 'wrinkle') in front of ant base, in raised 'ridge' where ant is mounted.
--Corners of square mounting hole in roof seem raised (with tiny seams or cracks at corners).
Rubber seal gasket on bottom of ant base appears okay.
Not sure how to:
1. Remove antenna base fully from square hole in roof.
Is there a squeeze clip, or need to remove inside liner to unscrew or release something?
2. Flatten (pop out) slight hollow in front of ant base (or could I live with this).
3. Flatten (if required) raised corners of square roof mount hole (or could I live with this--may possibly prevent ant base from fully pressing down against roof, not sure).
4. Replace any mount clip or parts that go into mount hole.
5. Re-install & seal ant base rubber gasket tightly enuf to avoid rain & spray wash leaks into roof & headliner.
Will be stopping by repair shops or dealer(s) for suggestions or pricing to repair.
But if possible would repair myself (wish to personally do & ensure tight base/roof seal upon repair).
[ On my old ranger, had repaired & sealed high center mount 3rd brake lamp 2 or 3 times. Factory & replacement gaskets had melted/shrunk/wrinkled & leaked a bit over time. Eventually purchased weather seal or backing rod (closed cell version, IIRC) foam tubes, and split/cut to adequately fit & seal lamp housing to roof back. Also swapped to LED bulb/s to reduce one heat source that may have helped ruin orig & initial replacement gaskets. ]
Guess if I can carefully seal rubber gasket (bottom of ant base) again to roof--in any reasonable manner--the slight hollow in front may collect a few tablespoons of water and normally dry without seeping under sealed ant base.
However, over long time, water collecting there (during wet roof conditions--rain or wash spray) could eventually find or create way to leak.
If a shop does repair after all (because more than I'm willing or able to accomplish), I hope to understand enough to avoid an unnecessarily large repair bill. Like, say, $1,200 ... or whatever. Perhaps comprehensive insurance would cover some (less a deductable), but just saying (and hope to avoid a claim).
Any tips on repair & seal?
Much appreciated. Thanks!
--Spif
Not sure how to:
--Spif
