Ride Vibration
Viator092
Louisville, KY
18 BMW 440i, 15 VW Golf TDI, 19 Ford Ranger Lariat
I have a Lariat Super Crew FX4 with a 3 inch Ready Lift and Nitto 285/60R18s on +18 wheels. I get a vibe in the frame, steering wheel and cabin at 65 mph on up. Aligned after lift. Road force balanced wheels. Tires all equal pressure. I threw the OEMs back on and all is well.
What gives? Bad tire? Can't think of anything else.
Lunchbox88
Logan
Missouri, USA
2019 Ranger SuperCrew FX4
New aftermarket wheels as well?
If not, then yeah I would suspect either a bad tire or someone was bad at balancing them.
Viator092
Louisville, KY
Yeah, XD Series Machetes. I had them balanced again after the install and then again with road force balancing. Guy at tire shop says they need to be balanced many times over a 10,000 mile break in. I don't go back to that place.
CoMtnRanger
Gregg
2019 XLT Ranger STX Supercab 4X4, 3" lift
A tire can be in balance and not be round, I had that happen on my first Ranger in 04.... one front tire was running out of round, and the opposite side had a ton of weights (which was the clue). The tire shop showed me the tire was in balance, then I pointed out it was not round by at least 1/8 inch, they replaced the tire and no more problems.
Hack_Actual
Justin
Oklahoma
2019 Ford Ranger Lariat FX4
Sounds like a tire and likely a front one based on what you say you’re experiencing.
Viator092
Louisville, KY
Back to shop that installed wheels and tires. I had rebalanced them elsewhere btw. The install shop says yup, out of balance and they note the other weights. Says good to go now after a rebalance. Still a vibe at 65-70 but not as pronounced. Hub centric rings on order and scheduled for tomorrow for install.
Viator092
Louisville, KY
Hub centric rings fixed the problem. Wish the shop would have put them on during the initial install. Not the first after market wheels I’ve bought but first experience requiring hub centric rings.
Lunchbox88
Logan
Missouri, USA
Glad you got it sorted out Jeff! Thanks for the follow up.
