Ranger performs well in IIHS crash tests
Discussion in 'General Ford Ranger Discussions' started by DakotaGuy, Jun 27, 2019.
  1. DakotaGuy
    DakotaGuy Well-Known Member
    First Name:
    Tom
    Vehicle(s):
    2019 Ranger SuperCrew XLT FX4
    Mar 1, 2019
    Black Hills, SD
    186
    160
    2019 Ford Ranger crew cab driver-side small overlap IIHS crash test 0-11 screenshot.png
    The redesigned 2019 Ford Ranger crew cab earns good ratings in all but one of the Insurance Institute for Highway Safety's crashworthiness evaluations, as well as a superior rating for front crash prevention. A marginal headlight rating, however, keeps the pickup from qualifying for a TOP SAFETY PICK award.
    The Ranger was last sold in the U.S. as a 2011 model in regular-cab and extended-cab versions. The 2019 Ranger is available as a crew cab, called the SuperCrew, and as an extended cab, called the SuperCab. IIHS only evaluated the crew cab version.
    The Ranger earns good ratings in five crashworthiness evaluations. These include the driver-side small overlap front, moderate overlap front, side, roof strength and head restraint tests. It earns an acceptable rating in the passenger-side small overlap front test. In that test, the passenger's survival space was maintained reasonably well, but forces on the right lower leg indicated a risk of injury.
    The pickup comes with a standard front crash prevention system that earns a superior rating in IIHS tests. It avoided a collision in the 12 mph test and reduced its speed by an average of 24 mph in the 25 mph test. The system has a forward collision warning component that meets the criteria set by the National Highway Traffic Safety Administration.
    The Ranger falls short of a TOP SAFETY PICK award because it earns only a marginal headlight rating for each of its three available headlight options. Combined with its other ratings for crashworthiness and front crash prevention, an acceptable headlight rating would have earned the pickup a TOP SAFETY PICK award.
  2. Lunchbox88
    Lunchbox88 Well-Known Member
    First Name:
    Logan
    Vehicle(s):
    2019 Ranger SuperCrew FX4
    Jun 21, 2019
    Missouri, USA
    272
    172
    Overall looks pretty solid
  3. EcoRanger
    EcoRanger Well-Known Member
    First Name:
    Doc
    Vehicle(s):
    2019 Ranger XLT 301A SuperCrew 4X4 2015 Ecoboost Mustang 50 Year Appereance Package convertible
    Aug 20, 2018
    West By God Virginia
    801
    1,029
    Garage Profiles:
    Having the LED driving lights makes the headlights a non issue.
    BDoc likes this.
  4. Formula Indy
    Formula Indy Well-Known Member
    First Name:
    Phillip
    Vehicle(s):
    Apr 18, 2019
    Carmel, IN
    104
    130
    Garage Profiles:
    I wish manufacturers wouldn't have headlight options. Just give everyone the safest/best option. Unfortunately it cost them a Top Safety Pick, silly.
    BDoc and MSgt G like this.
  5. SandBaja
    SandBaja Well-Known Member
    First Name:
    Larry
    Vehicle(s):
    2019 Silver FX4, 501A pkg, fully optioned,2012 Rubicon, 2017 Cherokee, 2018 Volt
    Jun 15, 2019
    San Diego
    126
    144
    Occupation:
    Almost retired
    it earns only a marginal headlight rating for each of its three available headlight options. Isn't LED one of the 3? I thought there were only 2 options...LED and non LED.
    EcoRanger likes this.
  6. VAMike
    VAMike Well-Known Member
    First Name:
    Vehicle(s):
    2019 Ranger Lariat SuperCab
    Feb 22, 2019
    1,216
    948
    They didn't like any of the headlight options so it wouldn't have made a difference. This is a relatively new test IIRC, and nobody is doing that well on it.
    SandBaja likes this.
  7. VAMike
    First Name:
    Vehicle(s):
    Feb 22, 2019
    1,216
    948
    LED, non-LED, and non-LED without auto highbeam.
  8. rangerdanger
    Vehicle(s):
    Oct 9, 2018
    SF Bay Area
    3,464
    2,287
    Garage Profiles:
  9. VAMike
    First Name:
    Vehicle(s):
    Feb 22, 2019
    1,216
    948
    And that's only if you count the headlights, and only on their top trim; the lower trims score worse than all ranger trims. And they're only good with auto-highbeam, which basically never activates most of the time in my area and especially not in conditions where visibility matters and the lights are otherwise scoring low (that is, going around a corner when there are oncoming lights killing night vision.) I mostly tend to think the IIHS headlight tests are on the border between BS and an ok idea that's ahead of its time. I'm sure in a few years the manufacturers will adjust the lights to score better on the test, but I'm not completely convinced how much better things will be if they're designed to do well on the test. (Except for failing headlights with too much glare--those blinding headlights are the devil and someone should definitely give them a bad rating.)
  10. DHMag
    DHMag Well-Known Member
    First Name:
    Dale
    Vehicle(s):
    2016 Kia Optima SX, 2019 Ranger XLT Crew cab
    Oct 25, 2018
    San Antonio, TX
    361
    228
    So THAT is how you remove the grille....
  11. VAMike
    First Name:
    Vehicle(s):
    Feb 22, 2019
    1,216
    948
    XL is halogen; I don't think there's been a standard incandescent headlight on a new car in decades. The difference is the auto high beam functionality.
    t4thfavor likes this.
  12. the1mrb
    the1mrb Well-Known Member
    First Name:
    Matt
    Vehicle(s):
    2019 Ford Ranger, XLT FX4
    May 22, 2019
    Duluth, MN
    487
    673
    Occupation:
    Garage Profiles:
    The headlights do leave something to be desired for me. But that's why I'm adding more lights to it, especially for all the open road driving I do here in Northern Minnesota. Gotta see those deer, moose, and bear a good deal before smacking right into them.
    BDoc likes this.
  13. SandBaja
    First Name:
    Larry
    Vehicle(s):
    Jun 15, 2019
    San Diego
    126
    144
    Occupation:
    Almost retired
    I would like some for off road in Baja. I'm leasing so I'm reluctant to do much, and will probably live with what I have for now.
  14. BDoc
    BDoc Well-Known Member
    First Name:
    Bryan
    Vehicle(s):
    2019 Ranger Lariat FX4 SCrew
    May 3, 2019
    WA
    401
    673
    Occupation:
    Garage Profiles:
    How many of you saw that first picture and went "NOOOOOO, you killed a Ranger!"?
    As someone still waiting on delivery, I'll admit, I wanted to weep a little. :LOL:
    EKSU likes this.
  15. Anthony
    Anthony Well-Known Member
    First Name:
    Anthony
    Vehicle(s):
    Feb 7, 2019
    Connecticut
    496
    577
    Occupation:
    COO
    Garage Profiles:
    Dammit, I was hoping to be the one to write that. Take your well-deserved "like". :like:
    BDoc and DHMag like this.
Share This Page
