Think it pulled on on the cv when I moved the lca down, it's not the hub side it's the diff side cv that sounds like the noise/ rattle is from wondering if it's fixable or needs a shop at this point to fix/ replace.what happened?
did you pull the splines out when you fitted the CO's?
