No, I haven't had that problem.When filling up my truck with gasoline the auto shutoff to the nozzle at pump does not shut off once the tank reaches full capacity. Instead it keeps on pumping gas and floods the side of my truck! Anyone else have this issue??
Can't say I've ever had this issue. Do you always fuel at the same station? That might be the problem.When filling up my truck with gasoline the auto shutoff to the nozzle at pump does not shut off once the tank reaches full capacity. Instead it keeps on pumping gas and floods the side of my truck! Anyone else have this issue??
Fuel inlet hose just above the tank was probably collapsed or crimped.Can't say I've ever had this issue. Do you always fuel at the same station? That might be the problem.
When I first the title to your post I thought you were gonna say the auto shut-off kept shutting off before it was done fueling. My mom had a 2013 Escape that always had this problem. It would fuel for maybe two seconds and shutoff. Costco was the worst but she had it other stations too. We always attributed it to the Capless Easy Fuel.
The vent tube on the pump nozzle can clog and make it hair trigger. try putting the nozzle in only 1/3 of the way and/or use the middle detent instead of wide open.In my experience this has more to do with the pump then it has to do with the vehicle. Unless you do have an older vehicle with a stopped up vent tube that can make the pump click off quite a bit. But if it overflows without stopping that’s the pump but not your truck.
As others have said it’s the pump. If it isn’t the pump it’s the user.When filling up my truck with gasoline the auto shutoff to the nozzle at pump does not shut off once the tank reaches full capacity. Instead it keeps on pumping gas and floods the side of my truck! Anyone else have this issue??
My wife's Jeep Wrangler did that. We went to a couple different pumps... did the same thing at each pump.When filling up my truck with gasoline the auto shutoff to the nozzle at pump does not shut off once the tank reaches full capacity. Instead it keeps on pumping gas and floods the side of my truck! Anyone else have this issue??
Hi Michelle,When filling up my truck with gasoline the auto shutoff to the nozzle at pump does not shut off once the tank reaches full capacity. Instead it keeps on pumping gas and floods the side of my truck! Anyone else have this issue??
Thank you so much!Hi Michelle,
Yep....happened to me once when the truck was brand new. I was mystified as this is totally unacceptable to Ford. So next time I when to a different pump...no problem. I even crawled under the truck with a flashlight and inspected for a kinked vent or some other assembly problem...Nope...all was well.... Then noticed the suspected pump had a new nozzle with a different color protective rubber bumper.....It was the pump handle...not the truck....
What I would recommend is to have the dealer inspect for a problem before your next fill up and to also select a different pump at the same station if you can do so...
