Order Question - electronic locking differential vs open differential
sodakchuck
Chuck
Spearfish, SD
1999 Ranger 4x4
I preordered an XLT supercrew 4X4 with the electronic locking differential and when I first checked the order tracking website that option was clearly shown in the order; last night when I went back to the site the order showed the 3.73 open differential rather than the e-locking. My question: who should I contact regarding this? I don't think this an issue I take my local dealer. Any suggestions?
Strokerduster
Refresh your screen and it will correct, mine does the same thing also.
Schafies
Indiana
2017 Ford Explorer. 2019 Ford Ranger.
I see a similar issue with my order on the tracking site. In the pkg. section 302A has an empty bullet point. The missing verbiage is the "8 way power driver and passenger heated seats with lumbar support". The build site shows it in the 302A pkg. Refresh doesn't correct it.
sodakchuck
Chuck
Spearfish, SD
1999 Ranger 4x4
My order page also says open differential even though I ordered a locking differential.
I wouldn’t worry too much about it.
Thanks, I will continue monitoring as my build date 2/04.
skibuff
Kevin
Northern California
2009 Ford Escape / 2019 Ford Ranger XLT Lighting Blue
Same mine lists open differential and my original build sheet lists E Locker
RodSlinger
Atlanta
2011 Dakota
Everything I've read shows the Ranger includes Ford's standard trac-lok limited slip rear diff as standard on rear axles (and front for 4x4). The e-locker is of course optional.
The limited slip in my Dakota is very tight and never had an issue where a locker would have made the difference somewhere. Is the Ford trac-lok not very aggressive or is the e-locker just better for extremely uneven surfaces? Like one wheel on ice and the other pushed up against a rock kind of situation.
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
The standard Ranger axles are not limited slip...they are just plain old "open" differentials. And the front differential is non slip and there is no option for a e-locker
skibuff
Kevin
Northern California
Mine correctly updated to show the locker today. I have no build date now thought
MadMartigan
NY
Ford
I ordered a 4x4 w/o the rear locker. Is the rear locker something that can be added easily by the dealer down the road or is it something that can only be done during the biuld.
Geoff
NYS
Retired Engineer
During the build. It would require swapping out the axle assy afterwards.
ajvester
Chicagoland
Toyota Tundra
Thanks. I figured it had to be done during build
You can always add an aftermarket locker like ARB or Detroit. You basically replace the innards of the diff with the aftermarket part and you can either get a auto locker, electric locker or air locker.
