Official: Euro-Spec 2019 Ford Ranger Raptor Specs Released!
Administrator
Administrator
Ford has just released the full details of the Euro-spec 2019 Ford Ranger Raptor!
Here are some of the highlights:
  • 210 HP, 369 LB-FT - 2.0L EcoBlue diesel engine
  • 10-speed automatic transmission
  • 2,500 kg (5,511 lb) towing capacity
  • 283 mm (11.1 inches) of ground clearance. This is 56 mm (2.2 in) more than the stock Ranger
  • 32.5 degree approach angle
  • 24 degree ramp over departure angle
  • 150 mm (5.9 in) wider track than standard Ranger
  • 32-percent increased front damper travel, 18-percent increased rear damper travel than standard Ranger
  • Terrain Management System with 6 driving modes
  • Sales start in Europe in mid-2019
NEW BAD-ASS FORD RANGER RAPTOR MAKES EUROPEAN MOTOR SHOW DEBUT AT IAA COMMERCIAL VEHICLE SHOW IN HANNOVER
  • New Ranger Raptor – the toughest, highest performing version of Europe’s best-selling pick-up – on display at Hannover CV Show ahead of 2019 sales launch
  • Developed by Ford Performance, the awe-inspiring Ranger Raptor supports thrill-seeking outdoor lifestyles and can tackle the harshest off-road terrain at speed
  • Go-anywhere ability delivered by ultra-strong chassis; bespoke suspension and tyres; 213 PS, 500 Nm EcoBlue engine; 10-speed auto gearbox; Terrain Management System
COLOGNE, Germany, Sept. 18, 2018 – The new Ford Ranger Raptor – the toughest and most high-performing version ever of Europe’s best-selling pick-up – is storming into Europe, as the bold new model wows motor show visitors for the first time at the IAA Commercial Vehicle Show in Hannover, Germany.
Developed by Ford Performance for the true enthusiast off-roader, the first-ever Ranger Raptor will go on sale to thrill-seeking customers in Europe in mid-2019 powered by a Bi-turbo version of Ford’s 2.0litre EcoBlue diesel engine that delivers 213 PS and 500 Nm of torque; and Ford’s new 10-speed automatic gearbox.
The commanding presence delivered by the ultimate Ranger’s imposing dimensions and extreme styling is supported by a unique Ford Performance chassis optimised for high-speed off-road driving and go-anywhere capability.
“Forget everything you think you know about pick-ups,” said Leo Roeks, Ford Performance Director, Europe. “Our new Ranger Raptor is a different breed – a thoroughbred desert racer and extreme lifestyle off-roader that can toil with the best of them in the harshest of working conditions.”
A dramatic video of the Ford Ranger Raptor in action can be viewed here:
Rugged yet refined
Built to withstand high-impact off-road events, Ranger Raptor’s unique, super-strong reinforced chassis frame uses high-strength, low-alloy steels to endure the punishment delivered by off-road racing.
Raptor’s race-bred suspension has been specifically crafted to tackle fearsome terrain at high-speed while remaining in complete control and comfort; has a 150 mm wider track; and adds 56 mm to the ride height compared to a standard Ranger.
FOX shock absorbers with Position Sensitive Damping provide higher damping forces at extremes for unparalleled off-road capability, and lower damping forces in more moderate conditions for a smoother ride on-road. Front damper travel is increased by 32 per cent, and rear travel by 18 per cent.
The high performance dampers with 46.6 mm pistons are supported by aluminium control arms, with protruding shock absorber towers at the front and a bespoke new coilover rear suspension arrangement featuring an integrated Watt’s linkage that allows the axle to move up and down with very little lateral movement.
Front braking is performed by twin-piston front callipers, increased in piston diameter by more than 20 per cent compared with the standard Ranger pick-up to 51 mm, and 332 mm by 32 mm ventilated discs. Rear braking performance is also enhanced with a 54 mm diameter rear calliper, and 332 mm by 24 mm ventilated discs.
All-terrain BF Goodrich 285/70 R17 tyres have been specially developed for the Ranger Raptor. Measuring 838 mm in diameter and 285 mm wide, the design offers a tough sidewall to take on the most formidable environments with confidence, and an aggressive off-road tread pattern which provides an iron grip in wet, mud, sand and snow conditions.
“The standout experience of the Ranger Raptor, hands down, is how far you can push it off-road and still ride like a millionaire on-road,” said Damien Ross, chief program engineer, Ranger Raptor, Ford Motor Company. “Everything about the Ranger Raptor builds on the already outstanding sophisticated feel and functional capability of the Ranger, and then goes further. From a driving dynamic fun standpoint, it is really an exceptionally special vehicle.”
The unique chassis design is combined with optimised off-road geometry that delivers 283 mm ground clearance along with a 32.5-degree approach angle, and ramp-over and departure angles of 24 degrees, providing impressive go-anywhere capability.
Ranger Raptor also features unique underbody protection to deflect off-road obstacles. The new bash plate is made from 23 mm thickness high-strength steel in addition to the Ranger’s standard engine and transfer case under-shields.
Impressive in form and function
Available in Ford Performance Blue, Colorado Red, Absolute Black, Frozen White and Conquer Grey colours with contrasting Dyno Grey accents, the new Ranger Raptor’s aggressive design is driven by performance and functionality.
A dramatic new grille inspired by the world’s first factory-built high performance off road truck – the Ford F150 Raptor – dominates the space between the xenon high-intensity discharge headlights and above a frame mounted front-bumper system. Offering desert durability performance, the front bumper also includes new LED fog lamps with functional air-curtain ducts that improve air flow around the body.
Striking, flared composite front fenders are to designed to shrug off damage from off-road usage, and allow for longer suspension travel and oversized tires. The side step boards are designed specifically to prevent rock spray from hitting the rear of the truck, and feature drain points for sand, mud and snow.
The Ranger Raptor remains a true workhorse. A modified rear bumper features an integrated tow bar with 2,500 kg capacity. Two front recovery hooks are able to shift up to 4,500 kg, and two at the rear are rated 3,800 kg. A 1,560 mm by 1,743 mm load tray has been designed with the weekend explorer in mind, able to accommodate dirt bikes or jet-skis, in addition to work tools and supplies. For convenient access, an EZ Lift Tailgate uses a new rod assembly to give the owner a 66 per cent reduction in the force required to close it.
Ford Performance DNA is present throughout the interior, which delivers quality craftsmanship, harmonious colours and durable materials for driving scenarios from the high street to high altitude. The bolstered seats are specially designed for off-road high speed support with a dual-firmness cushion for ultimate comfort and suede-effect materials for enhanced grip.
Blue stitching and leather accents feature throughout. Lightweight, racing-style magnesium paddle shifters for crisp gear changes are easily accessible near the perforated leather hand grips of the bespoke steering wheel, which uses an on-centre marker to help drivers keep track of wheel position off-road, and is embossed with the Raptor logo.
Tuned for all Terrains
Ranger Raptor enables drivers to select from six Terrain Management System modes to tackle a wide range of terrain and driving scenarios, including:
  • Normal mode – emphasising comfort, fuel economy and driveability
  • Sport mode – more responsive for spirited on-road driving
  • Grass/Gravel/Snow mode – designed to inspire safe and confident driving on off-road slippery and uneven surfaces
  • Mud/Sand mode – tuning vehicle responses for optimum traction and momentum in deep, deformable surfaces like loose sand and mud
  • Rock mode – specifically for low-speed rocky terrain where smooth controllability is key
  • Baja mode – tuning responses for high-speed off-road performance, just like drivers need in the famous Baja Desert Rally
Ford engineers extensively tested the new Ranger Raptor’s powerful Bi-turbo 2.0-litre EcoBlue and 10speed automatic powertrain to prove durability in the most fatiguing conditions, including running the high-pressure and low-pressure turbochargers until they glowed red-hot for 200 hours non-stop. The two turbochargers work in series at lower engine rpms for enhanced torque and responsiveness. At higher rpm, the larger low-pressure turbocharger delivers peak power.
Ford’s 10-speed automatic transmission is shared with the F-150 Raptor and has been created with high-strength steel, aluminium alloys and composites to optimise durability and weight. The wider ratio-span results in better acceleration, responsiveness and fuel-efficiency.* Real-time adaptive shift-scheduling algorithms help ensure the right gear is selected at the right time. A unique transmission calibration also includes a Live in Drive function, with paddle shifters always available for manual gear selection override.
Driver assistance and safety technologies that boost confidence for drivers facing unknown off-road challenges or demanding working environments include an enhanced version of Ford Stability Control incorporating Roll Mitigation Function; and Electronic Stability Control; Trailer Sway Control; Hill Start Assist; Hill Descent Control; and Load Adaptive Control.
Practical technology at hand
Sophisticated technologies designed to make the new Ranger Raptor comfortable and convenient on- or off-road include Ford’s SYNC 3 communications and entertainment system, which enables drivers to control audio, navigation and connected smartphones using simple, conversational voice commands. The system is compatible with Apple CarPlay and Android Auto™, and features SYNC AppLink for voice-activation of a range of smartphone apps.
The system’s central 8-inch colour touchscreen can be operated with pinch and swipe gestures, and features sat-nav technology that comes into its own when off-roading in remote locations, even offering a “breadcrumb” feature to leave a trail when exploring unchartered areas. FordPass Connect embedded modem technology delivers connectivity on the move.
“The new Ranger Raptor delivers all the tools a thrill-seeker could ask for,” Roeks said. “Like a motocross bike, snowmobile and an ATV in one – it’s the ultimate adventure pick-up.”
JeeperNRM
Cali
Jeep Grand Cherokee
Besides engine how much of this can we expect to transfer over to the US version you think?
rduvall
Altima
I don't know if Ford tightened up the body panels on the World spec Ranger Raptor (RR) like they have the new US spec Ranger. If they didn't, I would expect them to do that so it holds a little more true with the US Ranger. I expect a high output 2.3L Ecoboost in the RR which would keep power to weight below that of the F-150 Raptor. Other than that and the engine, I think we should expect to see it nearly untouched.
PA
2011 BMW M3, 2011 Hyundai Tucson, 1994 VW Corrado SLC
I hope you are incorrect on this point. I don't need either a turbo engine that runs out of steam after 5k rpms or only comes to life after 4k rpms. The only way to get a fairly smooth power band (actually, it's more the torque curve) on a turbo motor is to add some cylinders.
rduvall
Altima
I hope I am wrong. Unfortunately I have run the numbers and it just doesn't work in Ford's favor any other way based on existing engines. That said, have you see the torque/power curves on the 2.3L in the Ford Focus RS? The torque starts to drop off at 5500 rpm but the hp is there to take it up for it all the way through redline. Couple that with a 10 speed transmission that has been raved about by every critic who has driven it and I do think they are on to something. Still no numbers on the base 2.3L Ranger engine yet so we don't have any idea how much room is left for a high output version yet.
PA
I suppose it depends on what number's you're referring to. Perhaps on a price perspective, it may not make sense. Though with the 2.7t being used on the F150 and Edge, I would think there would be enough room to make it work financially for the RR. You did mention power:weight of the potential US-spec RR to the F150 raptor, but I don't think that would at all be a problem. Ford can either up the power of the HO 3.5TT, which has a ceiling much higher than the current 450hp and/or it could also de-tune the 2.7t for RR duty. There's precedent for both approaches.
As far as the hp vs torque curve, torque is what you feel. My old GTI had a 2.0t that worked great until 5500 rpms and was terribly after that point in time. From that point forward, I've paid close attention to the torque curve of modern 4-cyl turbo motors to look at the torque spread. I have yet to see one that makes power clean to redline. 6-cyl+ motors can mask this a lot better, and in most cases, the torque drop-off isn't nearly as large as a 4-cyl. Having written that, if Ford can work some type of magic on the 2.3t for RR duty, I might reconsider my position, but I'd absolutely have to drive it before buying.
rduvall
Altima
An F-150 tuned 2.L EB puts out 325HP and 400 lb-ft of torque. At those numbers, at the expected weight of the RR, it would be comparable to the F-150 Raptor. Here is the rub. The 2.7L is tunable right now. Why drop and engine into a truck that could immediately be tuned in such a way as to outperform Ford's flagship vehicle? The numbers just don't make sense.
As far as the torque curve, you aren't taking the 10-speed transmission into account. Every driving account I have found on it says that it keeps the vehicle in the optimal power band at all times. But this is all educated speculation until they release the Ranger engine specs.
