Off topic, if I may, advice needed
Jon54
Jon
Germantown, TN
2013 Ford Edge Ltd
I’m always impressed by the auto knowledge on this board. I grew up in the muscle car era where a tune up included changing out the distributor cap and setting the timing with a timing light.
simple question from an old guy. Again, off topic, but I need to replace the headlight bulbs in my wife’s ‘12 Honda CRV. I Google the topic and am overloaded with options. Help?
dmeyer302
Daniel
Carthage, MO
2014 Escape, 2016 Odyssey
Mechanical Engineer
Generally speaking, newer headlamp units have a large (~3") rubber dust cap. Remove that and the bulb unit is revealed inside. Snap off the electrical connector, and twist out the bulb. Pretty simple. I don't know about your CRV specifically.
Going to be tough topic to give any specific advise on unless someone on the forum has experience with Honda CRVs. First and simplest is to replace in kind, you manual will give you bulb number required. Or, your local parts dealer will have a book you can look your vehicle up in to tell you what bulb will fit. If you are looking to replace stock halogens with LEDs, the options are countless. You still need to know bulb number you are replacing. Fitting into your housing under the dust cover is probably the biggest issue you need to deal with as all LEDs are not the same physical size even for the same bulb number. My best advise is to find a Honda CRV forum, I'm sure there is one, and ask your question there.
One point of advice don't touch the bulb itself with you fingers. The oils from your hands will cause the bulb to burn out prematurely. Especially halogen bulbs.
Jon54
Jon
Germantown, TN
2013 Ford Edge Ltd
I confused by the selection of bulbs. Sylvania has about 5 options. I may just pick one in the middle price range.
Probably a safe choice. Some will be brighter but have shorter life others will be whiter than the one halogens. If I remember correctly Sylvania has an expected life span grad on their package so you can compare. Make sure to replace in pairs.
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
One thing to keep in mind is the ones that promise to be brighter won't last as long. You can't go wrong with the SilverStars
slowmachine
New Hampshire
Bulb changing procedure is on page 309 of the downloadable owner’s manual. Definitely wear rubber gloves to keep skin oils off of the bulbs. Wipe with alcohol if needed. This is a 10-minute job
http://techinfo.honda.com/rjanisis/pubs/OM/0A1212/0A1212OM.PDF
It was mentioned above that the brighter bulbs have shorter service lives. This is true, and Sylvania provides nominal life spans, in hours of usage, for each grade of bulbs. I installed the Silverstar Ultra bulbs about a year ago, and they are still working fine. I have read that a person who is 60 years old needs 3-4 times the amount of light to see the same detail as someone who is only 30. At 58, no bulbs are too bright. The LED headlights were a large factor in me choosing Ranger Lariat over a lower trim. They are good enough.
cfhgarza
Ohio
Great perspective here and something I didn't consider. Seems like the Silver star Ultras might be a good choice.
Jon54
Jon
Germantown, TN
2013 Ford Edge Ltd
The CRV has really been a great value. 8 years old, 150,000 miles and still runs and looks great. My bride of 43 years (65 years old) needs more light.
davidham
East Tennessee
2020 Ranger XLT
Look at the life rating on the bulb. You will see the bulbs that are greatly brighter than the stock bulb also have a very smaller life rating. I felt the stock bulbs in my last vehicle were bright enough considering the shortened life of the "upgrades".
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
The other issue as the cars age is the lenses become cloudy and pitted dispersing light everywhere except where it should be going. Much like our old eyes.
Brighter bulbs help overcome that and so can polishing the lenses or replacing them.
Jon54
Jon
Germantown, TN
2013 Ford Edge Ltd
Guys, thanks. Silver star ultras installed. Happy wife, happy life. Who’d know the original bulbs lasted 8 years. I replaced simply because they got dim.
