Colo_Ranger
Got it. I caught that this morning, after I wasn't half asleep on the couch...It is the ARB plate mated to the ARB bumper.
Do you have pictrues of how you modified the skid to work with your 589 plate? I have the plate coming in and now I need to modify my ARB.I've beat the hell out of mine....
Probably time to start looking for a lift...
Hey @Colo_Ranger post #93 on this thread has the best pictures of my install. I ended up grinding the corners of my 589 mount near the lowest bolt hole and cutting a notch on the ARB plate to get it to fit..Do you have pictrues of how you modified the skid to work with your 589 plate? I have the plate coming in and now I need to modify my ARB.
Should not be any issue with it since it's the same frame.For the FX2 trucks with which looks to be an skid plate, but is mostly fake(shame on ford!) the ARB Full kit will mount up correct?
That was a shitty move on Ford’s part to change to that plastic half non skid plate. The ‘19 and I believe early ‘00 trucks had the metal full plate.For the FX2 trucks with which looks to be an skid plate, but is mostly fake(shame on ford!) the ARB Full kit will mount up correct?
AgreedThat was a shitty move on Ford’s part to change to that plastic half non skid plate. The ‘19 and I believe early ‘00 trucks had the metal full plate.
So I'm missing the factory bolts on the front skid. I sold my FX4 skid and all hardware that came with it prior to picking this up. Can anyone link me what I need to purchase? Just 2 bolts right?I installed mine this weekend. No lift and no helper. Used a Pelican case to prop up the plates since they are a bit heavy for one guy to lift up alone while crawling under the truck.
Made some notes on the install sheet attached due to some omissions and misprints. Will figure out the Oil Plug situation closer to my oil change time.
Hi, looks like a great install, would like to see all the photos but can’t get all of them on the site, can you send to me [email protected]? Thanks, MikeI installed mine this weekend. No lift and no helper. Used a Pelican case to prop up the plates since they are a bit heavy for one guy to lift up alone while crawling under the truck.
