TruckNoob
- Thread starter
- #1
Was installing a Draw-Tite hitch, and everything was going peachy, for 3 out of the 4 mounting bolts. I noticed that when removing the bolt it was slow and sticky, and now the bolt will only go in about a 1/4 to a 1/3 of the way back in. I tried the bolt in the other holes, and it works, and I tried a different bolt in the problem hole, and it won't work; so I concluded that the threads in the hole were cross-threaded/damaged.
So I know the bolt head is 21mm, and the internet tells me that it typically goes with a 14mm bolt; but the bolt has a taper to it, and the bottom measures 14mm, but the top of the bolt appears to measure (using a digital caliper) 15mm. I've purchased a fairly expensive tap and die set which gives me access to a 14mm tap and a 16mm tap, but no 15mm tap.
Anybody have to go through this mess before? Or have any experience with these bolts? I'm going to use the 14mm tap and hope for the best. This was supposed to be such an easy job.
