Midsize Truck Comparison: Ranger vs Tacoma, Colorado, Canyon, Frontier
Discussion in 'General Ford Ranger Discussions' started by rduvall, Oct 5, 2018.
  1. rduvall
    rduvall Well-Known Member
    Vehicle(s):
    Altima
    Feb 7, 2018
    165
    92
    #1 Oct 5, 2018
    Figured I would post this so I can just update it as more information rolls out. If there is incorrect information please let me know. I would be happy to explain anything you think is dubious. Ranger highlighted stats are guessed and are not known at this time.
    **Last Update: 10-18-18
  2. DHare
    DHare Well-Known Member
    First Name:
    Vehicle(s):
    2019 Ford Ranger Lariat - Saber; 2014 GMC Terrain
    Sep 28, 2018
    Missouri
    330
    194
    Which body style (SuperCab or SuperCrew) are the Length figures for?
  3. Xtreme Thunder
    First Name:
    Vehicle(s):
    Honda
    Aug 21, 2018
    New York
    Remember, if you are comparing Extended Cab, 2wd, that will get you 1,860 lbs payload. If you are in the market for Crew Cab, 4x4, that starts at 1,500 lbs, add options, and payload rating will further decrease.
  4. rduvall
    Vehicle(s):
    Altima
    Feb 7, 2018
    165
    92
    4 door for all trucks. Each manufacturer has different nomenclature. I am using best rates for the newly added towing/payload figures. I will fine tune them for the specific vehicle configs.
    DHare likes this.
  5. rduvall
    Vehicle(s):
    Altima
    Feb 7, 2018
    165
    92
    I am aware. I used the best numbers for each truck in the towing and payload section. I will update those as soon as I can collect all the information for the specific vehicle configs.
    DHare and Xtreme Thunder like this.
  6. DHare
    First Name:
    Vehicle(s):
    Sep 28, 2018
    Missouri
    330
    194
    #6 Oct 5, 2018
    Bed Length of 72" is for the SuperCab (2 Door)", but for 4 Door (SuperCrew) it is only 60". I presumed the wheelbase would go upwards about 12" on the SuperCrew vs. SuperCab; BUT looking at my order form, it shows a wheelbase of 126.8", so they must make the length adjustment by using the shorter bed on the Crew to keep the length and wheelbase the same. It's too bad they don't offer the 6' bed in the Crew cab model like Colorado does
    Administrator likes this.
  7. misanthrope
    misanthrope Member
    First Name:
    N/A
    Vehicle(s):
    Escape SEL 4x4
    Jul 14, 2018
    USA
    Great comparison chart thanks for sharing. This highlights how super competitive the Ranger is looking against the other midsize pickups! Looking forward to hearing how all this translate to real world driving reviews.
    rduvall likes this.
  8. Tra1969
    Tra1969 Member
    Vehicle(s):
    2014 Ford Escape Titanium
    Jan 30, 2018
    Hope the width dimensions are wrong. My 2014 escape is 72.4 wide. The Truck at the auto show look wider then a escape setting behind it. Looked the width of a Edge that is 76". But that was just a few of us eyeballing it for measurements.
  9. rduvall
    Vehicle(s):
    Altima
    Feb 7, 2018
    165
    92
    The cells marked with light yellow and the text greyed out is because the information isn't officially know. those are approximate placeholder values and will be updated when there is more information.
  10. JYC
    JYC Member
    First Name:
    Vehicle(s):
    2014 4Runner
    Aug 14, 2018
    NY
    Thanks @rduvall for this helpful chart. For the Ranger dimensions - do we expect that it'll be different than the international model?
  11. rduvall
    Vehicle(s):
    Altima
    Feb 7, 2018
    165
    92
    We should expect them to be similar. They stated that they used the T6 Ranger as the basis and reworked all the body panels. I used some T6 numbers as placeholders until we have actual reported numbers.
  12. Supertrooper
    Supertrooper Member
    First Name:
    Zach
    Vehicle(s):
    2015 Mustang GT
    Aug 14, 2018
    Charlotte
    You hope that it's wider or narrower than an Escape?
    I'm just glad that the Ranger will be significantly smaller than the F-150. I'm guessing that many of us are here because the F-150 is too large for us. If these preliminary dimensions inputted by @rduvall end up being accurate, the Ranger would 20-30" shorter and 7" narrower than the F-150 crew cab. That makes a huge difference when it comes to daily driving situations like parking!
    rduvall and DHare like this.
  13. Stumblios
    Stumblios Well-Known Member
    First Name:
    Brad
    Vehicle(s):
    2007 Ranger FX4 LVL II
    Aug 24, 2018
    Hamilton Ontario
    80
    58
    Im hoping the dimensions are similar to the the international. I can accept that it will be a little bigger than the 07 I drive now. But I specifically ignore the F-150 because it's to big for my needs. I think the hole point to the mid size market is to be smaller, if it's with in a few inches of the F-150 I don't see the point.
  14. Tra1969
    Tra1969 Member
    Vehicle(s):
    Jan 30, 2018
    I'm just thinking of the inside dimension in comparison to the outside dimensions. Looked a lot narrower then the F-150 at the show. Cab size(shoulder width) is what I will be interested in. My escape is pretty good, I would be good with that. True about the parking, my F-150 was a pain at times. Not much longer to wait to be able to actually sit in one. Can't wait.
    Larry Forrester likes this.
  15. Lrtexasman
    Lrtexasman Well-Known Member
    First Name:
    Larry
    Vehicle(s):
    Tahoe/Tundra/Fusion
    Oct 15, 2018
    75
    40
    I took the global Ranger mm measurement and converted to inches. They are as follows. Looks like the middle rear will have a floor hump which will make that seat cramped. Also I haven't seen rear a.c. vents. The rear legroom and width will be critical competing with Tacoma. Rear legroom is a big complaint for some Tacoma owners. Poor transmission shifts as well, although they seem to have a programming fix now.
    Length 211
    Width 78
    Height 72
    Front headroom 40
    Front legroom 41.5
    Rear headroom 38
    Rear legroom 35.5
    Wheelbase 126
    Ugga Mugga likes this.
Share This Page
