"Leveling" Kit for towing reasonably heavy
t4thfavor
Chance
I want the better shocks and coilovers of something like the FRP Fox Leveling kit. BUT I tow fairly heavy fairly regularly, so I don't want my headlights pointing at the sky. Is there someone out there that has one of the fancy leveling kits and has "unleveled" the truck for this purpose? I'm looking at the Fox kit because it seems to be the most reasonably priced, but I figured I'd ask if anyone has used it or something similar for this purpose.
-Chance
Advertisement
Cape Cruiser
Bret
Southern Delaware
31 Ford-20 Ranger Lariat FX4- 19 Ranger Lariat 4x2
retired mechanic
-Chance
Eibach's seem cheaper and you can choose front end height from 0-3 inches.
t4thfavor
Chance
  • Thread starter
  • Thread Starter
  • #4
Are you seeking a leveling kit that is quickly and easily unleveled for towing and then leveled again?
Generally I would like to leave it "unleveled" and just have better shocks and springs for when I'm not towing. Eventually when I lift the truck (< 2" is my goal), I will leave it similarly unleveled just taller.
TBR17
Manatee River Florida
2020 Ranger SuperCab Lariat FX4
-Chance
Level it the way you want it with no tow weight, adjust headlights to match, then add Air Lift or similar to the rear to compensate when loaded/towing.
Cape Cruiser
Bret
Southern Delaware
retired mechanic
Chance, I have the Eibachs on the rear and I just purchased the fronts but have not installed yet. Big difference on just the rears. Bret
Langwilliams
Langley
Lorain, Ohio
Mail Carrier
When my son in law levelled his cummings 2500 he towed a toy hauler with he added the air bags that added air to keep it level no matter the weight on the back. It wasn't a cheap solution an involved an air compressor an controller install.
If you want better front struts without the lift the Bilstein's an Eibach's can be set at stock height for the better ride. I guess you could set the fox coil overs at stock height, they come set at 2" lift.
t4thfavor
Chance
  • Thread starter
  • Thread Starter
  • #8
Are the ones you have called "Pro Truck Coilover 2.0"? or is it the "Pro-truck Lift System"?
The Lift System comes with rear shocks, but doesn't look adjustable while the coilovers are definitely adjustable, but are nearly as much as the FRP kit (i guess 200$ or so less which is decent).
So if you could tell me exactly what front and rears you have that would be great.
Cape Cruiser
Bret
Southern Delaware
retired mechanic
Pro truck level is what I have , the 2.0 are true coilovers. I got them on sale at stage 3 for 175 for the rears and 199 for the fronts. Bret
BigOlBish
2020 Ranger XLT FX4 Rapid Red
Could go with the OME kit which I believe includes a new leaf pack that would lift the rear at the same time as the front. Or just get the better coilovers and set them at 0" lift
Edit: forgot about about add a leaf. That + fox is about the same as the OME
JTDay
Josh
Mazdaspeed3, M3
EHS
+1 for OME suspension and towing if you want to lift the entire truck but keep the rake.
Alternatively, the Bilstein 5100 kit is all 4 shocks for less than $400 and can apparently be adjusted from 0-3" in the front. No rear adjustment. From what I've read, the Bilsteins are damped more firmly which can often result in a more comfortable ride for some.
t4thfavor
Chance
  • Thread starter
  • Thread Starter
  • #12
I assume this kit involves me disassembling the stock fronts and using the factory springs and cups?
EJH
Ed
Subarus, 2021 Ranger
Following along, as I have the same goal. I would like the Fox 2.0 kit, but haven't seen info on setting them lower than the shipped 2" lift. The Blisteins look to have very obvious set points. I'd like maybe 1" front lift.
JTDay
Josh
Mazdaspeed3, M3
EHS
The Bilsteins would require disassembly. Are you installing yourself? If it were me, I'd get a shop to take the springs off and on for you. They should have equipment that does this, not some janky spring compressor.
The Fox's are different. The shock body is threaded allowing the lower spring perch to thread up and down the shock body which adjust the height. Keep researching and you'll find what works for you. It's all good stuff.
Sashimi_Moto
WA
2012 E450 C-Class, 2019 Ranger Lariat 501A FX4
The issue you've suggested you want to avoid is headlight direction under towing load. The only way you can avoid having your headlights pointed at the moon is to maintain their proper level while loaded vs unloaded. That's it - whether you're at stock height or lifted - scenario doesn't change.
So the solution is then: A) eliminate rear squat when loaded (but this makes no-loaded driving poor) or B) install something that either limits squat; extra leaf, different jounce bumper and/or load leveling hitch OR install something to returns the rear to the proper height after loading (air bags).
Good luck.
Advertisement
Advertisement
