Information screen not working
It kind of sounds like it might be related to XL "calculator" screen (as some have called it) - I wonder if that screen is somehow more sensitive to heat than the XLT/Lariat screens?
Des everyone having the issue have an XL? I've never seen any of my screens blank.
mrodgers
Richmond, VA
2020 Ford Ranger STX
I have my new Ranger XL since March and during the recent heat wave were having in Virginia I have experienced the Dash Information screen dim/faded until the car cools down. What I observed today was got in after work, dash thermometer showed 103 degrees, display was normal. As I was driving out of the parking lot the display dimmed/faded down, after 15min of driving with the a/c on the display returned to normal, the temp was 97 degrees.
I think it is heat related either a harness or the power source to the display is being affected. If the LCD was failing it would not recover, once heat damaged they usually stay affected so the next part is the power supply or input source that is heat sensitive.
Just my 2 cents but has anyone brought this up to the dealership yet?
Well if it was//is heat related then mine should be a melted piece of plastic by now. lol. On average it's 108 this time of year and a few weeks ago it was 117 and mines never had any issues. Also factor in my garage temps are another 10+ degrees hotter and when I'm at work my truck sits and bakes in the sun all day long. Maybe a bad batch of XL/XLT gauges?
12Bravo20
Missouri
2020 Ford Ranger XLT FX4
I have the same issue with mine and I am fairly certain it has to do with the heat. I live in Arizona and it gets really hot here. Every day when I leave work my center screen doesn't work at all. By the time I get home, it has cooled down with the AC on and the screen starts working like normal again.
I had the exact same thing happen to me yesterday in my XL STX, my truck is Shadow Black. It was sitting in the driveway all day in direct sun and I got in to go somewhere around 3:00PM and the only part of the center info screen that was readable was the middle of it. After about 10 minutes with the AC on, the screen came back on.
Augie81
I had a black screen on startup today. First time it happened. My music started playing from my USB drive then quit and a black screen. It seemed to happen right about the time the screen usually tells me my phone has paired with bluetooth. I had to restart my truck then it worked fine. The age old fix for a lot of computer issues, turn it off and back on again. :)
I made a few more stops while out and about and it didn't repeat.
Edit: Oh, I misunderstood the original post. It wasn't my info screen by the speedometer, it was my sync screen.
No problems with my screen in this heat. ? Truck was sitting outside at work since 6:00am and this was the actual temp after driving for 10 minutes.
What a surprise! ?
Was an even bigger surprise when I went to grab the shifter! ? I forgot my sunshade at home, won't be that dumb again tomorrow.:headbang:
12Few
Michael
Phoenix, Az
2020 Ranger XL
Mechanic
A
I, too am having my dash cluster LCD "black out." I do have an XL, and it does seem to be heat related......
Only happens when cabin temps are above 140*.
My 2020 Ranger XL is at the dealer, right now, for their 2nd attempt to fix. It appears they are gonna try to wait out the Phoenix summer, and hope for a new start next July.
As a moderator, any way you could move these Sync screen reports to a different thread? This is about dash clusters.
A
This whole thread is about what you describe, so I'm not sure why you think it should be moved. Are you thinking it is in the wrong forum?
VegasP11
Ian
Kansas
2019 Lariat FX4
I believe what he is asking is that all replies in this thread that are from people saying their Lariat SYNC screen does not have this issue be moved to it's own thread. This issue with the center dash display on non-Lariat trucks and people keep saying they don't have this problem with a Lariat SYNC display. The two are not related at all.
Glocker
Boca Raton
I'm thinking you might not be having a problem because your screen between the gauges is different than the screen they have. They have the XL package monochromatic LCD screen between their gauges where as yours is going to be the color LCD screen.
I'm not sure what good that would do - it doesn't seem to make sense to create a thread about something that doesn't exist. What would be the topic of a thread with people with Lariat displays saying "mine doesn't do this"? Maybe I'm just being dense. All the smoke from the fires around here might be messing with my brain.
I guess it possible but there are many areas of the country where it get really hot. Between CA,UT,AZ,TX, and basically the whole lower east coast it gets pretty toasty in the summers. You'd think that if there was a massive problem Ford would've redesigned these mid 2019?
Glocker
Boca Raton
Car companies have let massive mistakes slide in the past. LOL *Cough, cough, Chevy ignitions*
