- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 164
- Messages
- 7,542
- Reaction score
- 10,751
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2012 Nissan Frontier, 1994 F150 XL, 2022 Ford Transit
- Occupation
- Field Service Technician
- Thread starter
- #1
So as some may already be aware of I did get a Garmin Overlander back in August. Well this last week I got myself a Garmin Tread Overland GPS.
Now I'm sure some of you have questions as to why(and how does this guy have that kind of money). We shall get to all that.
As for how I have that kind of money to toss around? Well that happens when you don't have vehicle payments anymore.
Now I won't argue that the Garmin Overlander is still a good GPS that is designed to help with OffRoad Navigation. That said there some things that got on my nerves like how the OffRoad Routing was simply a strait line like in this picture...... Don't ask me why but Garmin said it was normal.......
One other thing was me wanting to add a Backup Camera to the old Pathfinder and the Garmin BC 35 being discontinued and Garmin telling me to basically pound sand as they are in the process of phasing this GPS out(I suspect in the next year or two).
Something I was able to find out with the Tread Overland was the fact it actually has Adventure Routes and Trails as an option that you can adjust from 1 to 4(1 being all pavement and quickest route and 4 being as scenic as possible including OffRoad Trails). Of course you can still adjust routes to your liking.
I also got to mess with the Route Planner and it is a neat tool. As long as you set your little way points before the end point you will be able to have a route planned through many different Trails instead of the street if one wishes to do so.
One neat feature i do like is the weather forecast and radar in real time. You have to have your cellphone connected via Bluetooth with the Tread app in order to access this. You also have to have Cell Reception which can be a pain if you are remote and don't have a cellphone booster on the vehicle. That said if you have the InReach active you can still get a general Forecast for your location at that time especially if you plan to stay put for a few(or at least in the area for a bit).
The Tread Overland still has the Track Recorder like the Overlander. Still works in the same manor and is a great tool if you find a track you like and want the information saved.
There is the Group Ride Radio that can be added, but it is pricey and must be justified. For you to use it with other individuals, other individuals must have a Garmin Tread GPS with the Group Ride Radio as well. It operates using MURS and will give you realtime location of the individuals in the group. I have yet to use this feature as I have yet to justify the cost at this time.
And if you are wondering, yes you could use the phone in place for the Group Ride Radio, but the moment you lose Cell Reception it stops working. Not very useful OffRoad unfortunately in that particular manor.
Some other things to be noted, the Garmin Tread does not have automatic brightness control for the screen(a slight pain) and does not have voice control(I like it this way) like the Garmin Overlander.
Loading GPX Files is still possible, but a slight pain to figure out. You still have access to the Garmin Explore library on the Tread, but you cannot directly download the file to the GPS like you can with the Overlander. There are two ways to do this. Either be on the Home Computer and have Garmin Explore open and import through there or through the Tread App on the Phone you can import the GPX files through there. Both do work an can be synced with the Tread Overland GPS.
Overall I can say I do like the Tread Overland a little more than the Overlander a little bit. That said it is still a big purchase and something to think about before making the purchase. That said if you feel it is right for you and you can justify it then I say go for it especially since Garmin is pushing for the Tread Series GPS Units for OffRoad use.
EDIT: forgot to add that the Tread Series does have addon antennas available for the GPS and InReach. Both are external for better performance. Can't say if the GPS External Antenna is needed, but the InReach is something to consider due to the vehicle body and glass possibly causing some issues.
