Hubcentric Rings
Discussion in 'Tires / Wheels / Brakes' started by RangerDave, Aug 1, 2019.
  1. RangerDave
    RangerDave Active Member
    First Name:
    Vehicle(s):
    2019 Ranger Lariat SuperCab
    Apr 15, 2019
    Canton, GA
    54
    Garage Profiles:
    Just bought a set of Black Rhino wheels from Discount Tire Direct. According to DiscountTire they fit the Ranger. However when they arrived there was no included rings so I called customer service. Was told Black Rhino doesn't make rings that will work on the Ranger. Now I was under the impression that you must have centering rings. What is everyone's opinion on this?
  2. BcP28
    BcP28 Well-Known Member
    First Name:
    Bennett
    Vehicle(s):
    2019 Ford Ranger, 2015 Ford Edge Sport
    Jun 28, 2019
    88
    240
    Occupation:
    As long as the hub diameter of the wheels is equal-to or greater-than the hub diameter on the truck, there shouldn't be any issue. Most aftermarket wheels are 'lugcentric' and rely on conical lug nuts for centering. I don't foresee any issues with it.
    Edit: Discount Tire Link
    https://www.discounttire.com/learn/hub-centric-vs-lug-centric
    Hack_Actual likes this.
  3. Msfitoy
    Msfitoy Well-Known Member
    First Name:
    Vehicle(s):
    2003 MINI Cooper S Modified, 2009 Chevy Cobalt SS Turbo Modified
    1,863
    2,752
    Occupation:
    Mack Trucks Senior Industrial Designer
    Garage Profiles:
    Same here. My Fuel wheels came with hub centric rings that didn't fit my hub. Mounted them without them and no problems so far.
  4. Rinn69
    Rinn69 Well-Known Member
    First Name:
    Vehicle(s):
    Nov 25, 2018
    N. Central Iowa
    529
    440
    Occupation:
    Retired USAF MSgt
    Garage Profiles:
  5. OP
    RangerDave
    First Name:
    Vehicle(s):
    Apr 15, 2019
    Canton, GA
    54
    Garage Profiles:
    Thanks for the help.
  6. Daniel Scarbrough
    Daniel Scarbrough Active Member
    First Name:
    Daniel
    Vehicle(s):
    2019 RANGER FX4 LARIAT W/ SPORT PACKAGE 501A {HOT PEPPER RED}
    May 9, 2019
    Richmond, VA
    62
    #6 Aug 6, 2019
    Ordered custom 106.3 mm -> 93.1 mm rings for my FUEL Nitro wheels
Share This Page
