How to keep 12V outlets alive?
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
Anyone know where the setting is in Forscan to keep the 12V outlets inside the cab on all the time? I like to keep my phone in there charging and it sucks that it powers off after a while.
I did this one and it didn't work: 726-39-01 setting XXXX X1XX XXXX, changed 1 to 0
JesseS
Jesse
NorCal (Roseville)
Retired Army & LEO
The powerpoint timer is only designed to power the 12v sockets for either the set time or when the door is opened, you can change the time it is live while sitting in the truck but regardless of the setting the power will be cut when the door is opened. This is to keep the battery from going dead. If you want an always on circuit you will have to run a new line from the battery.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Sorry thats not right - the power ports and the tap above the driver rear wheel stay on for a set time after the doors are closed. You can chnage the timeout to I think 18 hours (IIRC) with FORscan. If there is a drain hooked up the battery management system will override and shut the aux power off when the battery gets too low.
VegasRanger
VegasRanger
Las Vegas
Damper Salesman
Do you happen to know what setting it is in forscan?
JesseS
Jesse
NorCal (Roseville)
Retired Army & LEO
That would make more sense, but the info I got was from the FOREscan forum when I was looking for the same info as @VegasRanger. As you seem more informed can you supply the setting in forscan to adjust the stay alive time? I looked in the BCM but setting the 726-39-01 made no change when set to 32400 (9 hrs). I cannot find anywhere in the manual where it says how long the powerports stay energized after turning off the truck and exiting.
JesseS
Jesse
NorCal (Roseville)
Retired Army & LEO
I guess I can always plug in a light and time it.
micl9
Apex, NC
Sorry I dont recall the settings and I set mine back to stock as I was having battery issues - not related to the settings!
There are 2 big FORscan threads check them out. One is a Wiki so it should be on the 1st page.
Good luck
JesseS
Jesse
NorCal (Roseville)
Retired Army & LEO
Good luck
Checked there, and the forscan forum, no luck. Other people having the same issue, the ports not staying live long enough for what they need. I think the powerport time out setting in the BCM has a max amount, but I can't find the value.
micl9
Apex, NC
Not to be snarky, but... Use the search Luke!
So I checked my notes and did a quick SEARCH
When I used this I set it to always on so my bed lights could be turned on prior to turning ignition on.
And @Ed Venture 's post gives the method to change the time
I found a Forscan setting for 2011-2020 Explorers that *seems* to work for setting a specific timeout for the power points on the dash.
BCM-726-39-01
1194 XXXX XXXX= 1 Hour, 15 minutes (Default)
0001 XXXX XXXX = 1 Second
5460 XXXX XXXX = 6 hours
A8C0 XXXX XXXX = 12 Hours
FD20 XXXX XXXX = 18 Hours
FFFF XXXX XXXX - 18 Hours, 12 minutes, 15 seconds (Max)
What I discovered was that the first four numbers is the Hexadecimal setting for the time in seconds. If you enter each value in to a Hex to Decimal calculator (https://www.binaryhexconverter.com/hex-to-decimal-converter) you get the timeout in terms of seconds:
"1194" = 4500 seconds = 1 Hour, 15 minutes
"0001" = 1 second = 1 Second
"5460" = 21600 seconds = 6 Hours
"A8C0" = 43200 seconds = 12 Hours
"FD20" = 64800 seconds = 18 Hours
"FFFF" = 65535 seconds = 18 Hours, 12 minutes, 15 seconds
So, I used the Decimal to Hex converter and put in 60 seconds and got 3C. With that, I padded with zeros to get "003C" and plugged it in. Lo and behold - it worked!
My goal was to have the power point run for a minute or two before my dash cam shut off and kicked in to parking mode. I was getting a bunch of false positives from getting out of my truck and hopefully it will help alleviate that.
Before adding it to the first post, I'd like to make sure that it works for others. Has anyone else had success with this?
Ed
PS - I also found this at the Explorers site:
BCM-726-39-01
XXXX X*XX XXXX = 0 - Always On, 1 - Timeout enabled
I didn't try this one, but I know there were a few of you out there that wanted the outlet to always stay on. This might do the trick for you.
VegasRanger
VegasRanger
Las Vegas
Damper Salesman
I tried this below and set it to 0 and didn't work.
BCM-726-39-01
If you don’t want to mess with editing the HEX code, go into the BCM configuration and look for Powerpoint Feature, set it to Disable. This set the powerpoints to always on once you cycle the ignition to turn them on. I use this to run my 12v fridge of the bed powerpoint.
micl9
Apex, NC
Yep Forgot to mention that
You can use the menus.
micl9
Apex, NC
