silverflash
- Thread starter
- #46
But in our case, new rangers, u can program the spare fobs and keys yourself with the ignition if you have two working chipped keys already.Unaware of any such law. It must be a state law, and Maine is like the Wild West of the East. ?
I've been a locksmith since 1999. We cut keys by code upon request without any requirements unless it is a restricted key.
A key cut to code would still not start our trucks (or any modern vehicle). The key still needs to be programmed, and that requires plugging into the ODBII with a programmer.
The 48 bit code the transponder uses for communication has magnitudes more possibilities for uniqueness than the physical cuts of the key. Somewhere out there every key has a doppelganger with a different code but the same cuts. It might be for a focus or an explorer, lots of Ford's use this same key blade and cut specifications for many models over many years, even if the heads/remote parts are different.
Any decent automotive locksmith can pick and decode a door lock with a Lishi decoder, or take a door panel off to remove a door lock to decode. They do not need the key code at all. Often, starting from scratch, the automotive locksmith can make you working keys faster and for less $$$ than the stealer when you lose your keys.
The dealership here hires a locksmith to come once a week to make duplicates and replacement keys. The dealer receives a bulk discount and does NOT pass it along ?.
