20WorkRanger20
- Thread starter
- #1
I was attempting to direct a small power inverter directly to the power that plugged into the back of auxiliary power #2. I removed the connector, cut and spliced my inverter to the wires. Now the wire do show any power. I'm starting fresh today trying to eliminate the why.
Fuse 16 appears to be good still.
I tested these multiple times prior to install and with key on there was power. I noticed if there was a load on the outlet and the key was switched off power would remain on. I'm wondering if I'm running into an issue that is trying to eliminate battery draw down?
Thanks for any help
Thanks for any help
