Headliner sagging
cory1848
cory1848
Cory
Davenport, Fl
2019 Ford Ranger XLT 4x4 Sport
Sports Photographer
then your decision is made....take it to the dealer.
there so far isnt any magic answers here
I didn't plan on a DIY fix. But figured someone here might know that has pulled the liner out... Trying to get as much information as possible.
Arizona
CEO of DeeZee
I do remember reading a while back that someone pulled theirs out to mess with the antenna. IIRC they wanted to get rid if the shark fin? Mine doesn't move at all behind the dome light so if yours does then I would think the dealer didn't put it back on right.
Arizona
CEO of DeeZee
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
its a hack
because sometimes its quicker, easier and less stress to simply avoid the dealership who will deny any problem in the hopes you go away. thats dealer 101.
the relationship will sour and you'll never be happy with said dealership.
you can be sure headliner work is not a high volume item at any dealership, and mechanics arent likely very skilled with them on one model vs a whole garage full of them
the service manual is lacking details, and theres no guarantee that if they pull it a second time the problem will be solved.
fix your problem with a simple solution and move forward.
*edit, besides, when you pull the light out, maybe the issue will be obvious and you'll see a clip missed it target or something.
Same issue here....
Ill just pop out the dome and stick some high vht tape in there. Easier than driving to a stealership.
cory1848
cory1848
Cory
Davenport, Fl
Sports Photographer
Same issue here....
Yours has a lot of play behind the dome light? Like it is missing a support block or attachment point? Have you ever had the headliner out?
cory1848
cory1848
Cory
Davenport, Fl
Sports Photographer
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
Yes.
Attachment point.
Never.
cory1848
cory1848
Cory
Davenport, Fl
Sports Photographer
Yes.
Attachment point.
Never.
Interesting. Thanks for this info. Wish I could see engineering manuals on this to see what is supposed to be there or not there.
Zaph
Got a snake scope to look around in there after you pull out the light?
I originally bought mine to see if I dropped a screw inside my motorcycle engine but found myself using it for all kinds of uses. They aren't that expensive these days as long as you don't get a high end Fluke model or something.
Ranger_Rocks
Wandering
Wanderer
If the magnet is still attached to the headliner, push up until it attaches ?
If the magnet is attached to the roof and not the headliner - problem.
Locate the magnet with a piece of metal ?
cory1848
cory1848
Cory
Davenport, Fl
Sports Photographer
The question is, is there a magnet at all?
Ranger_Rocks
Wandering
Wanderer
cory1848
cory1848
Cory
Davenport, Fl
Sports Photographer
Going to pop out my dome light tomorrow to see if those gray blocks are there. I doubt they are.
As for magnets this is a pic from f150 I found on eBay. You can see the support with what appears to be magnets on the top. I wonder if the Ranger gray blocks have magnets on them as well.
cory1848
cory1848
Cory
Davenport, Fl
Sports Photographer
So I am not losing my mind. Check this out. Removed the dome light and stuck my phone up there and took a pic. The attachment mount is ripped off the headliner. The gray foam isn’t attached to the roof. It’s just a spacer block. This attachment holds it up. Now to fight with the dealer on fixing it.
cory1848
cory1848
Cory
Davenport, Fl
Sports Photographer
since you're already in there.....glue it and be done with it.
I have to go back to the dealer for another issue (seatbelt bucket getting replaced) so will use this as a teaching moment for them since they don't know there is an attachment point there. They need to make it right.
