Has anyone adjusted their Fox "Tuned by Ford Performance", front shocks while on the vehicle?
andros
2019 Ford Ranger Lariat
Pretty much title, when I got this installed they didn't adjust them at all and my nose is sticking way up now. Hoping to bring it to an even level. From the instructions I read they warn not to do this while installed, I assume in fear of striping the threads. Is that something I should actually be worried of, was thinking I could also jack the car up and get some spring compressors in there while still installed to take some tension off and adjust them. Really don't want to completely remove them and deal with all of that.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Im not sure on these. Some shocks can be done wheels down, others cant. Are the springs new too? Might take 1000 miles to settle. And if you lower it you need an alignment again. It will throw everything off a bit.
andros
I've put around 3000 miles on em, they aren't settling more than this. Planning to get an alignment after
ScarzRanger21(2.0)
Eric
Auberry, CA
2021 Ranger 4x4, 2019 Ranger Fx4
Electrician
Idk man, if it says not to do it while they’re on the truck then I probably wouldn’t. There’s a reason for that even if it’s not obviously evident. It would be pretty shitty to start adjusting things and realize you just screwed something up. I would personally follow the instructions just to be on the safe side.
